stealership timing belt inspection
Old Feb 1, 2006 | 04:45 PM
siembad13's Avatar
Default stealership timing belt inspection
Whats the deal with the timing belt inspection? I called up the stealership to check for recalls on my car and they told me the lower control arms needed inspection and the timing belt needed inspection. I know the reason for the control arm inspection but the tech couldnt give me an answer for why they needed to inspect the timing belt. Anyone know the reason behind the recall?
Old Feb 1, 2006 | 04:54 PM
techbod's Avatar
Default RE: stealership timing belt inspection
tensioner and idler pulleys defect/cheap materials
Old Feb 1, 2006 | 05:22 PM
cary12's Avatar
What year/model does the timing belt recall effect?
Old Feb 1, 2006 | 05:24 PM
techbod's Avatar
98 to 2002 it should be on the recall list
Old Feb 1, 2006 | 05:26 PM
techbod's Avatar
http://www.google.co.uk/search?hl=en...+recalls&meta=
Old Feb 1, 2006 | 05:30 PM
techbod's Avatar
the company has a duty by law to inform you of a recall regardless if the car was bought through a dealer
Old Feb 1, 2006 | 05:34 PM
Jestnomen's Avatar
6th Gear
Old Feb 1, 2006 | 05:37 PM
techbod's Avatar
now you know what the small print looks like lol
Old Feb 1, 2006 | 05:39 PM
brrman's Avatar
not cheap materials, but a definite defect in the tensioner's engineering.
I took this when I changed my tensioner/belt (it had failed due to the defect)
techbod's Avatar
but it doesnt exempt you from your statutory rights
