steering help.....
96 2.8 140,000:
when i turn the steering wheel i get a loud noticable whinning noise, what could it be? i would like to go to the mechanic with a little knowledge on my problem, thanks AF in advance |
RE: steering help.....
your power steering fluid could be low. I know fords make this noise very often and its a symptom of low fluid. check the level and get back to me.
Probably low fluid or a toast pump
i herd there is a spring in there that squeeaks.
maybe the clock spring but i dunno
If it a gringing/whine from the power steering pump, check the fluid level. If low, fill it with Pentosin 11S only (not power steering fluid, or transmission fluid)) and look for the leak.
