steering problem...
Old Aug 22, 2005 | 07:26 PM
lilbrownindian's Avatar
Default RE: steering problem...
my squeaking in the steering wheel sounds like a door hinge that needs 2 be oiled, and it only does it when i pull out of a parking spot and take a turn out or something at a very low speed..never on highway turns, only like traffic light signals and stuff
Old Sep 1, 2005 | 12:41 AM
Jamaha80's Avatar
Thats what IM TALKIN ABOUT. I notice it at low speeds only also. What the F.
Old Sep 1, 2005 | 03:36 AM
sir_daft's Avatar
I JUST FIXED MY PROB! I had the same squeeking noise too... the problem was the steering column (at the U-Joint right by the firewall) was not lubed. I just took out the steering column, soaked the u-joint in some oil, and it's as good as new. I never had a hard time turning the wheel, I just heard squeeking and it was SOOO ANNOYING.
Old Sep 1, 2005 | 04:51 AM
flyboy's Avatar
the p/s fluid can also loose its viscosity to the point that it leaks past the seals and doesn't build pressur. If it is easyer to turn when the engine is cold than hot this is probably the prob. that what mine is doing, I just havent done anything about it.
Old Sep 1, 2005 | 10:42 AM
Galilee's Avatar
Not enough tension on the belt to the servo pulley. When you load up the servo at low speed the belt slips and squeal.
gold2734
Sep 3, 2009 08:58 PM
Lastb0isct
Feb 17, 2009 03:15 PM
99'A6
Sep 26, 2008 08:35 AM
B5nightrider
Oct 3, 2005 03:34 PM
mitao2000
Feb 8, 2005 02:41 PM
