Still running like sh*t
Old Apr 27, 2007 | 10:08 PM
NuYorka103185's Avatar
Default Still running like sh*t
So I recently put in my K04 and since then if I accelerate quick I get this poppong sound and a cell. Thouhgt it might be exhaust leak but turns out know. The cell I got was cylinder 2 misfire. Would a misfire on cylinder 2 cause that popping sound as well as the definite small loss of power whenever you hear a pop?
Old Apr 27, 2007 | 10:16 PM
audi_pa's Avatar
Default RE: Still running like sh*t
sounds like a bad coil pack. do you have a vag cable?
I had the same symptoms as you and it was a coil pack. i had 2 coil packs go bad in less than 3k miles. my car has 60k on it. coil packs are cheap enough though.
Old Apr 27, 2007 | 10:40 PM
AteUrV8's Avatar
coil pak player. easy fix
Old Apr 27, 2007 | 11:09 PM
onepoint8tee's Avatar
Swap coil pack with another cyl. and see if misfire follows. A misfire will cause a pop/backfire due to theunbrunt fuel/gases igniting in the cat.Obviously, ita misfire causeslack of power... I thought misfire trouble shooting practices were were common knowlege round here?
Old Apr 27, 2007 | 11:19 PM
AteUrV8's Avatar
ORIGINAL: onepoint8tee
i was waiting for this answer...
Old Apr 27, 2007 | 11:26 PM
I had already figured coilpacks and am getting some new Hitachi E's but wanted to double check so if that did not correct the issue I knew which direction to move. Thanks guys hopefully after I get em swapped she'll be growling again. For now I have to sit here and take being embarressed by my cousins stock 05 GTI. "whimpers" anyway I'll let you guys know how it goes
inflictor
Jan 19, 2017 01:48 PM
So-Cal
Apr 7, 2013 01:47 PM
susyhun
Sep 30, 2011 05:31 AM
EnviedA6
Nov 16, 2007 05:38 PM
A4 Effort
Jun 15, 2007 07:29 PM
