???stock amp???
Old Sep 4, 2007 | 08:10 PM
B5Bobby's Avatar
Default ???stock amp???
where is the stock amp located??? in a 99.5 a4
it is the audi concert stereo
Old Sep 4, 2007 | 08:53 PM
auditech79's Avatar
Default RE: ???stock amp???
I don't think the concert radio has an amp. If it does it will be behind the driver's side trunk trim.
You will have to take off the rear trunk trim, then pry back the left side trim and it should be mounted right behind the trim.
Old Sep 4, 2007 | 10:57 PM
Bondga's Avatar
it should be a little mini amp attached to the driver side speaker. you cant see it unless you remove the speaker
Old Sep 5, 2007 | 08:02 PM
B5Bobby's Avatar
thanks for the help!! i found it! it is on the drivers side rear speaker and its shorting out. anyone know how much that speaker with the little amp goes for. or where i could get a deal on one??
THANKS AGAIN!
dc878mmm
Nov 2, 2013 02:02 PM
luxuryimports1
Oct 7, 2009 04:40 PM
Ringin'It
Feb 3, 2009 02:38 PM
A4 the Quattro
Nov 10, 2007 10:20 PM
