'Stuck' brake lights leaving me stranded... help!
Old Feb 19, 2007 | 06:13 PM
ErikCzajkowski's Avatar
Default 'Stuck' brake lights leaving me stranded... help!
I have a 2003 A4 Avant that I just bought over summer, so this is my first winter with the car.
I have a hard time explaining things, so I'll recap a typical night so you guys know whats going on.
[I've only been having this problem when the temperature drops below 35 degrees or so.]
I drive home from work at around 9 pm, park the car, come back out at like 11 or 12 to find my brake lights on as if someone was in the car pressing the brake pedal down. All it takes is for me to open the car, press the brake pedal down a bit for the light to turn off and I'm ok. Its the nights that I forget to do it that my battery drains down by the next morning, leaving me stranded. I've tried parking the car without the handbrake up to see if it works, and it doesn't. Any ideas?
Old Feb 19, 2007 | 06:36 PM
techbod's Avatar
Default RE: 'Stuck' brake lights leaving me stranded... help!
simple fix ( replace the break light switch ) to be found above the break peddle and a simple twist removes it and of course the same to refit
Old Feb 19, 2007 | 07:03 PM
david9999's Avatar
I agree, although you should be looking for a brake light switch not a break light switch.But if it is broken is it a "Break light switch"?
Old Feb 19, 2007 | 08:05 PM
wow... thanks guys. seems sometimes the simple fixes give us Pollacks a true test.
Old Feb 19, 2007 | 08:26 PM
Karl's Avatar
let us know if that fixes it, or if your brakes or still broke
Old Mar 16, 2007 | 04:54 PM
the 'brake' switch worked beautifully, no more problems.
only took about 15 minutes to replace.
thanks for the help as always!!!
Old Mar 16, 2007 | 06:25 PM
nickellis14's Avatar
ummm....don't Poles live in Poland....not Pollacks?
Old Mar 16, 2007 | 06:29 PM
techbod's Avatar
Old Mar 17, 2007 | 01:04 AM
zrwhat's Avatar
if it keeps happening, and you want a quick fix, just pull the lil plunger out on the switch, to get you to where you need to go till you get a new one.
Suzukis had a big problem with this happening too.
Tadyswoows
Apr 27, 2008 11:39 AM
exTTreme
Mar 11, 2008 10:20 AM
cvw
Feb 27, 2008 08:05 AM
paturk
Jun 29, 2006 05:22 PM
