Stupid Q?
Old Feb 13, 2007 | 12:01 AM
2000turbo's Avatar
Member
Default Stupid Q?
My friend gave me the vag com cable and the program, but i cant scan my car. He scanned it with his laptop but when i try to do it with mine I cant get the com port tested, have no clue why, he told me that my windows cant read the cable prob, can that be it, what do i do, please help, thanks.
Old Feb 13, 2007 | 12:57 AM
Lazer Viking's Avatar
Default RE: Stupid Q?
do you have an aftermarket headunit ?
Old Feb 13, 2007 | 01:08 AM
akielb's Avatar
Lazerviking, what are you taking about
you'll need a driver for your cable -
click here this is the one for my cable don't know if it will work for you
if he had the full program it can only work on one computer and cannot be transfered between computers or people
Old Feb 13, 2007 | 01:17 AM
wood_e's Avatar
Driver? If it's serial then NO you don't need a driver IIRC... my ebay cable works fine with vag version 3.11 and 4.09
Old Feb 13, 2007 | 01:29 AM
if an aftermarket headunit is installed im properly the vag reader wont be able to connect
and given the same scenario this can also do damage to the vag reader (reason why some shops wont hook it up to your car if you have an aftermarket headunit)
Old Feb 14, 2007 | 05:52 PM
akielb's Avatar
Thanks Lazer for clearifing your point. I've never heard of that before. Wood_e, yes serial cables don't use drivers but most cables are USB now - since serial is being phazed out. My new laptop doesn't even have a serial port. And I was also speaking from experience. When I first tried to use my ebay cable the program did the same thing to me and after I installed the drivers it worked just fine.
upallnight
Aug 21, 2010 09:00 PM
varun916
Oct 20, 2009 09:03 AM
ObnoxiousDrunk
Feb 3, 2009 01:07 AM
Darknight101
Aug 1, 2007 04:59 PM
Slowb5
Jul 2, 2006 01:12 AM
