Stupid turnsignal...
Well, my right turnsignal is not burned out, but i think it has a loose wire somewhere. it keeps going out, but if i give the cover a good wack, it works again for a bit. but its pissing me off because its getting worse. sometimes i have to wac it 3 or 4 times a day...
and i tried to take it off, but i realized i gotta tear my arbox out and such, but my on my airbox, i cant get the MAF plug out. normally i would stick a flathead into it and it would click whatever button is in there and it slides right out., well, it doesnt do that anymore and it wont come out...
help?
help?
You can also just remove the headlight, but the lights are supposed to be aligned if you do it that way. Id be willing to be that the bulb and socket have a burned out connection and they both need to be replaced. Also make sure the socket in the headlight assembly that the bulb socket slides into isnt melted.
Invest in a multimeter. Those are a must if you are going to work on your car. My FLUKE meter has helped me out numerous times. If you can get to the bulb again, check the wiring to see if you have continuity in the circuit.
