Subs with Stock Head Unit....
Old Feb 13, 2006 | 01:07 AM
A4_Spooler's Avatar
Default Subs with Stock Head Unit....
I was wondering, has anyone on here wired subs up with their stock head unit.... I have seen it done, as to how to do it though is my question....
Old Feb 13, 2006 | 01:28 AM
ibe3pac's Avatar
Default RE: Subs with Stock Head Unit....
ok... well i had the stock head unit and i didnt wire them to my head unit... i went to the back speakers... on your amp there is a thing called high input... those are the wires you need to connect to your rear speakers... but it is a pain in the *** running the wires under the carpet and trunk panels
Old Feb 13, 2006 | 05:45 AM
ShadowUCD's Avatar
I wired in an amp and a sub without changing the stock head unit. I used a hi-low converter. If you do a search you can find a ton of posts on a couple different ways to wire up an amp. It's not too difficult a job to do, but if the price was right, I'd pay someone else to do it.
Old Feb 13, 2006 | 05:47 AM
Jeff's Avatar
Zombie Defense Force
wheres the stock amp in the car?
Old Feb 13, 2006 | 06:55 AM
BadLuckAudi's Avatar
The stock amp is on the drivers side of the trunk under the side thing
Old Feb 13, 2006 | 08:08 AM
KiloByte's Avatar
So if you can do it this way, how much do you end up spending on the sub + amp + converter?
Old Feb 13, 2006 | 11:10 AM
ShadowUCD's Avatar
The cost pretty much lies in the amp and sub you buy. You can find cheap amps and subs and crazy expensive amps and subs. The converter is like $20 and of course a wiring kit for the amp will cost between $40 and $80 depending on the quality of the wire. I went with Alpine products and spent roughly $400 for everything. It definitely made a HUGE difference in the sound quality.
Old Feb 13, 2006 | 01:27 PM
BFlan2001's Avatar
if you have Bose you don't need a hi-lo converter, there are low level outputs in the trunk connected to your cd changer...you WILL however need to buy a ground loop isolator...i made a write-up for this but the site that hosts it is blocked on this site...email me and i can help you out
bflan2001@gmail.com
Old Feb 13, 2006 | 01:31 PM
Silver98A4's Avatar
i currently have subs and an amp installed with my factory bose system. I tapped the 2 rear speakers into this: http://www.crutchfield.com/S-nnk5YgF...tput&i=142SLC4
from there I wired that to my amp, then amp to subs....boom
In theory it was simple, but running all the wires and making everything look clean/professional took a little longer than i thought.
Old Feb 13, 2006 | 02:17 PM
A4_Spooler's Avatar
Do you have any pics of it wired in your car?
