Sunroof won't open
Old Oct 3, 2006 | 11:45 PM
N8sA4's Avatar
Default Sunroof won't open
My sunroof doesn't open on my 96 A4. When I turn the **** I can hear a couple click (sound like circuits opening and closing) but nothing happens. I don't hear the sunroof motor. I can open it using the hex key. Do you think its a bad motor? I checked the fuse and the connections and they are all tight. Any help would be appreciated.
Old Oct 4, 2006 | 12:25 AM
david9999's Avatar
Default RE: Sunroof won't open
Try contact cleaner in the opener.
Also open it manually and use white lithium grease on the rails. Open and close manually a few times and see if that fixes the problem.
I don't have my repair guide with me as I am traveling, so I can only give simple guidances.
Old Oct 4, 2006 | 04:04 AM
socal_A4's Avatar
this should work on your year audi http://www.kris-hansen.com/Audi/srswitch.htm
Old Nov 3, 2006 | 06:45 PM
N8sA4's Avatar
Turned out to be the motor. Worked well after I switched it out, but after I greased the rails it works even smoother. Thanks for the help. Was a pretty easy swap using the Bentley Manual.
Old Nov 3, 2006 | 06:50 PM
onepoint8tee's Avatar
ORIGINAL: N8sA4
Did you have to remove the headliner to get to the motor?
Old Nov 3, 2006 | 07:18 PM
N8sA4's Avatar
I had to remove the headliner partially. Bentley said that you had to remove the B pillar covers but I didn't. I only removed the sunroof switch, the sunvisors and clips and the "oh sh*t" handles". There was plenty of clearance without removing the B pillar covers which are kinda hard to put back on with the height adjustment for the seat belts. Bout a half hour of work.
Old Nov 3, 2006 | 10:48 PM
Deb38's Avatar
ya thats a real pain...my old A6 sunroof crapped out on me...it was actually stuck on the tilt mode for a whole winter hehe oh well i covered her up when i could...
Old Nov 3, 2006 | 11:56 PM
acetrebo's Avatar
There's more than 1 way to open it.....
Old Nov 4, 2006 | 10:32 AM
N8sA4's Avatar
ORIGINAL: acetrebo
LOL...acetrebo I'll let you know when I have any more mechanical problems...I've been looking for a good mechanic here in Columbus
Old Nov 4, 2006 | 12:47 PM
acetrebo's Avatar
LOL, glad you liked my post!
While I am not a mechanic by trade, I am in Columbus and would be willing to help if you ever needed it!
