in suspense for suspension
Old Apr 27, 2006 | 02:23 AM
StevenTownsend's Avatar
Default RE: in suspense for suspension
haha for sure. hope all goes well :]
Old Apr 27, 2006 | 02:25 AM
A4 the Quattro's Avatar
here it comes! : [sm=ttiwwp.gif]
Slowb5's Avatar
ORIGINAL: Jeff
haha lol im a budweiser man personaly
makes me dry heave...cant chug that stuff.....but for some reason i can chug mickeys????? *?*
Old Apr 27, 2006 | 02:31 AM
Slowb5's Avatar
tomorrow there will be pics man....keep your panties on.
Old Apr 27, 2006 | 02:34 AM
ORIGINAL: Slowb5
[sm=bustedsign.gif]
Old Apr 27, 2006 | 02:35 AM
trailboss's Avatar
the lower mounting bolt, in that hole is the nut, IIRC 16mm, and get a socket on the other
end and wrench away, push or pull down on the rear sub frame and slide the shock out.
connector for the rear brake light on the rear deck, disconnect
the rear deck, just push up on it, it has snap in pins
you have to remove the side pannels on the rear seat to get here, just pull the foam cube out
the two upper mounting bolts, do these first and then the lower and pull the suspension off
vice grips and a 18mm socket IIRC, and use an allen key to hold the strut from spinning,
compress the spring first on your old suspension and then remove the upper mounting plate
Old Apr 27, 2006 | 02:39 AM
Slowb5's Avatar
ORIGINAL: A4 the Quattro
ORIGINAL: Slowb5
[sm=bustedsign.gif]
lol, indeed.
Old Apr 27, 2006 | 02:44 AM
  #18
Jeff's Avatar
Zombie Defense Force
ORIGINAL: Slowb5
ORIGINAL: Jeff
i also like hard alc. its quicker. but beer is good for watching hockey cough cough go avs. im a corona fan also
Old Apr 27, 2006 | 02:45 AM
  #19
Slowb5's Avatar
ORIGINAL: Jeff
ORIGINAL: Slowb5
ORIGINAL: Jeff
you are cRaZy, i get so sick off hard alc...imo corona's **** water, no real taste. but good for chugging
personally, i prefer the leaf.
Old Apr 27, 2006 | 02:50 AM
  #20
Jeff's Avatar
ya i can chug corona becuase its so light. i like sam adams also and some times keyston if im desprite
