sway bar HELP !!!
Old Feb 8, 2006 | 04:23 AM
ExpLlclT's Avatar
Default sway bar HELP !!!
whats stock mm on front and rear sway bars?
what should i get i have Koni / STaSIS street coilovers they have some body roll on the freeway on ramps and i want to eleminate it as much as possible without spending a lot of bank and without damaging my subframe ... here are some sites i've seen sway bars on
http://www.modacar.com/products/Audi/A4/MODASWB/
Hotchkis Extreme Sport Swaybar Set 22mm rear 35mm front / 22mm neuspeed rear (will 22mm crack my subframe ? )
http://a4stuff.com/performance_suspension.php
19mm neuspeed rear
Old Feb 8, 2006 | 04:28 AM
PandaXpress's Avatar
Default RE: sway bar HELP !!!
none sport is 29mm/12mm
A4Sport/S4 is 29mm/16mm
for the B5s
for the body roll should lower your car and can u adjust te dampering to a siffer and harder setting
Old Feb 8, 2006 | 04:33 AM
ExpLlclT's Avatar
my coilovers are preadjusted and i would have to basicly re install them to change settings , thanks for stock sway bar width, would a 22mm rear sway crack my subframe or damage anything ? i think i will just go rear because its 200$ less than buying the set
Old Feb 8, 2006 | 04:37 AM
i have HSport and i like them
for the B5 they come with
To strengthen the rear sub-frame area, H Sport developed a billet aluminum reinforcement bracket system which bolts easily from the sub-frame to a hard point on the chassis.
http://www.h-sport.com/cgi-bin/EDCst...atalogno=22801
but it cost freakin 500.00 for the b5s DAMN
Old Feb 8, 2006 | 04:39 AM
ExpLlclT's Avatar
ya man thats what im saying should i think just get the rear ?
Old Feb 8, 2006 | 04:40 AM
beside alot of poeple recommend only upgrading the rear only anyways
i would of done that also but i had a great deal on the front/rear Hsports
Old Feb 8, 2006 | 04:43 AM
ExpLlclT's Avatar
22mm or 19mm be better for me ? without damage because i heard 22mm cracks subframe but is that bs ?
Old Feb 8, 2006 | 04:45 AM
i heard of that for the B5s but the Nuespeed rear sways kit comes with subframe reinforcements
Old Feb 8, 2006 | 04:47 AM
ExpLlclT's Avatar
the store is located local to me so should i have to ask for these renforcements or is it obvious they r there ? i jus don't wanna get jipped
Old Feb 8, 2006 | 04:51 AM
nuespeed rear sway
it says its included and nuespeed is a good name so i assume they wont rip u off
