System in B6!!
Old Oct 8, 2007 | 08:22 PM
sonneboz's Avatar
Default RE: System in B6!!
Sell the W7, with that money, save some more and buy the alpine w205. Save some more and buy an Infinity perfect 10" sub. WAY better setup than a jensen with a ridiculously heavy sounding sub
Old Oct 9, 2007 | 11:23 AM
pa4ul's Avatar
i would splice into the speaker wire if i was u and get a rca adaptor. hook up ur rcas from the amp to that box and u avoid all the hassel of dealing with the head unit. A cap would be a great idea so your lights wont dim and u dont have to get a new alt which means more $$$ to you. I got two 12's dual speakers in a loaded box that are misleading in price but louderthen hell.I believe it had something to do with installing a cap and having a 2000 watt amp. but hey i just install this ****!
Old Oct 9, 2007 | 07:15 PM
sonneboz's Avatar
ORIGINAL: pa4ul
Did you replace the components, or just add subs? If you just added subs (probably audiobahn) to the factory system than that is still a horrible setup. If you're going to replace the sub, you need higher quality components or you're going to be overwhelmed with bass, and in a '96 Civic on 100 spoke Dayton's kind of way.
PS - splicing the speaker wire is the worst thing to do for quality
Old Oct 12, 2007 | 10:43 AM
aluke's Avatar
Hey I was planning to do the same thing. Can you more fully describe where in the car is the stock wiring harness you tapped for your new sub amp?
ORIGINAL: BOPOH
i just finished installing some POS system. The way i did i just tapped RCA cablesinto stock subwires that come out from amp to sub, and same with REM wire. Rest is like regular system, sounds great. i was surprised that my car is put together so well thatNOTHING is making a vibrating noise inside, outside is only bumper. Powering amp was so easy but very different from DIY write up(atleast for my car)
Old Oct 12, 2007 | 09:40 PM
nihil's Avatar
If you tap straight into speaker outputs, particularly amplified outputs, you are going to need a level converter unless you want to either blow the input circuit on your amp, or deal with a huge increase in total harmonic distortion. A single bridged 8" or 10" sub in a 4th order bandpass enclosure located in the trunk would be a nice added kick to the factory stereo without overwhelming the factory speakers with muddy bass (basing this on my SymphonyII). Anything more and its just advertising, IMHO.
Old Oct 12, 2007 | 11:08 PM
BOPOH's Avatar
ORIGINAL: aluke
What car do u drive? i have B6 andi took entire car apart from inside, but ask me about B5 and i dont know a thing about it
Old Oct 13, 2007 | 01:43 AM
auditech79's Avatar
ORIGINAL: BOPOH
ORIGINAL: aluke
Almost the same thing, except for the amp is on the B6 is inpassenger's side in the trunk, the B5 is on the driver's side.
Old Oct 13, 2007 | 02:09 AM
  #18
Bogie's Avatar
subs=extra weight=slower
i have a box that used to be in my trunkwith 2 -12" Fujitsu Eclipse 10 series speakers and a big oldampwith 4gage wire hanging off it that makes for a prettygood coffee table these days.
Old Oct 13, 2007 | 02:39 AM
  #19
BOPOH's Avatar
Sorry to still this thread, but Bogie how the hell u drive over 100 mph and using 25.1 mpg, I LOVE UR GASMILEAGE.
Back to SUBS, if you have B5 there is write up for it https://www.audiforums.com/m_318162/tm.htm
B6 on the other hand is better to wire everything on the passenger side.
How I TAPED into stock wires: there is a long plug that goes to amp i looked up the colors of wires that connect tostock sub and found them on that long plug, striped the rubber from those wires and connected RCA cables. NOTE im not using my system as neiborhood speakers, im just using it for lil more bass.
If you want ur stock head unit make a lil different sound, hold MENU botton for about 5 seconds, it will bring out few options that u can flip through by clicking MENU and using RIGHT turn ****. Somethingthat ending on "..../NAV" if you put on "0" adds lil more base, and acts like "LOUD" button on aftermarket sterious (learned from AUDIZINE)
Sonita
May 3, 2015 05:58 AM
Polo2ya
Jan 10, 2014 08:33 PM
kellervernon
May 18, 2011 11:01 AM
headshok2002
10
May 20, 2007 01:15 AM
Dr. Audi
Jun 26, 2006 11:06 AM
