system to lean (bank 1)
I have another check engine light p0171 system to lean (bank 1) any suggestions? to fix
RE: system to lean (bank 1)
when i had that issue it was my maf... if there is someone around you with an audi, you might ask to try their maf and then get the code cleared drive around and if it dioesn't show a code, get a new maf from the vw dealer, will save you about 150 bucks
also do you have a boost guage? if so what psi are you running at? |
ORIGINAL: seana4 I have another check engine light p0171 system to lean (bank 1) any suggestions? to fix easy diagnostics lol |
it is pretty different on the 1.8 motor.......normally a maf, you might also try getting some electronics cleaner and clean the maf
ORIGINAL: turbo kraut it is pretty different on the 1.8 motor.......normally a maf, you might also try getting some electronics cleaner and clean the maf |
| All times are GMT -4. The time now is 02:06 AM. |
