tein basic coilover question?
Old Dec 11, 2006 | 07:47 PM
FLEX_rs's Avatar
Default tein basic coilover question?
im going to buy tein basic coilovers for my b6 a4, the description of the coilover is below but i dont understand the difference between "ride hight drop and adjustable range"
# Ride Height Drop: Front (-1.5"), Rear (-0.8") ??????????
# Spring Rate: Front (448 lbs), Rear (504 lbs)
# Adjustable Range: Front (-1.1" to -2.9"), Rear (-0.3" to -1.4")?????????
# Upper Mount: Front (OEM), Rear (OEM)
Old Dec 12, 2006 | 03:20 AM
DENIS415's Avatar
Default RE: tein basic coilover question?
damn nobody is helping out these days on the forums.......ride height drop is what its setup to be when you install the coilovers.......the range is how adjustable the coilovers are in case you dont like how the manufacturer has the ride height set up, so you can either lower it or raise it(the range).....pretty simple when you think about it!
sdsteez
Aug 7, 2008 12:21 PM
coleA4
May 16, 2008 01:16 AM
freestyleski
Jan 25, 2008 01:43 AM
thompsonader
Feb 14, 2007 02:37 PM
MEOONG
10
Jan 12, 2007 02:17 PM
