temp gauge not wokring
Old Aug 23, 2006 | 04:04 PM
keko2004's Avatar
Default temp gauge not wokring
i have just noticed that my temp gauge is not owrking at all. how can i got about fixing this?
Old Aug 23, 2006 | 04:08 PM
techbod's Avatar
Default RE: temp gauge not wokring
check all wire connectors to sensors/ fuses
Old Aug 23, 2006 | 04:11 PM
keko2004's Avatar
so it might be a fuse?
Old Aug 23, 2006 | 04:14 PM
techbod's Avatar
could be but all the other things could be as well
Old Aug 23, 2006 | 04:19 PM
InsaneHatter's Avatar
could also be the ECT ( Engine Coolant Temp.) Sensor being bad... costs at msost 15$ and takes 5 minutes to replace.
Do check the wiring on it though, most ECT's that go bad have erratic readings before they completely die.
Do you have A CEL?
Old Aug 23, 2006 | 04:23 PM
techbod's Avatar
ECT would give starting issues and CEL would come on ( good point )
Old Aug 23, 2006 | 04:48 PM
keko2004's Avatar
CEL is check engine light right? if so, no i dont. i have checked the fuses and they are all good. but i do have another question about my fuses. i noticed that these fuse ports, dont have fuses in them:
11 - Cruise control(auto trans)
16 - ABS, ASR
41 - ABS again
the others missing are vacant in the book. should i put fuses in the ones that are missing?
also, you guys have to realize, that im a noob with this stuff. so when you tell me to check wiring. i have no F'IN idea what wire to check. pardon my language. you guys are the closest teachers and help that i have without paying a million dollars. so i do appreciate all your help.
Old Aug 23, 2006 | 04:51 PM
techbod's Avatar
stick to one problem at a time the other fuses are for cars that have these functions
Old Aug 23, 2006 | 04:52 PM
keko2004's Avatar
doesnt my car have abs? 98 a4 1.8t qu?
Old Aug 23, 2006 | 04:56 PM
techbod's Avatar
you will end up confusing the issue stick to the main issue then we will talk about the others
