temp level drops when heat on???
I was just wondering if this happens or happened to anyone else and if its a big deal or not or even if someone knows what it is and how to fix it.... Basically when im driving and my car is at normal tempature, I will blast the head (I live in Seattle so its always freezing here!) then I well keep driving and look at my gauges and my temp gauge will drop, so i turn it off and after about five minutes of driving it goes back up???? any ideas? i appricate the help in advanced....
your heater core is working as a radiator.. and your fan is helping displace the heat that is on the heater core therefor cooling the temps
yadda yadda yadda..
since your a fellow PNWer check this out
http://forum.nwquattro.com
yadda yadda yadda..since your a fellow PNWer check this out
ORIGINAL: Redgoat
yadda yadda yadda..
thanks man, should i worry about it or is it no big deal? also it my engine gets WAY louder when the heat is on... should i try to fix somethin or leave it be? Again thanks for the quick response
Its really nothing to be concerned with. If it raises or drops rapidly or sporadically I would think youre having thermostat problems, but if it just drops when your pumping out heat that would be a normal response.
ORIGINAL: blackheart
awesome man thank you so much i appricate it, it does kinda seem like it drops real low but its prob cause i blast it w/ the heated seats on haha.
ORIGINAL: A4nicator
Well.. the heated seats are electronic, not related to the heater core.
