Terrible sound on 2002 A4
Old May 17, 2007 | 03:59 PM
mikowen10's Avatar
Default Terrible sound on 2002 A4
This morning i was driving to work all of a sudden my car starting making some loud sounds...now when you start it or accelerate it sounds so loud , almost exactly like a harley bike or even worse....does anyone have any idea what may have happened ? did I blow something ? maybe an exhaust ? can a bad oxygen sensor do that ? Help please!!
Old May 17, 2007 | 04:12 PM
wolfdog's Avatar
Default RE: Terrible sound on 2002 A4
Vague. Can you elaborate? Did you get out and walk around it to try and locate the source? From your incomplete description, it sounds like you have a hole in your exhaust system. Maybe it's that flex joint that looks like this:
http://www.pacesetterexhaust.com/images/flexjoints.jpg
Old May 17, 2007 | 04:15 PM
acetrebo's Avatar
Yeah, sounds like an exhaust problem.
Probably the flex pipe. I just bought a new one for mine from carstuff.com for $73 shipped for the whole downpipe that has the flex pipe in it.
Old May 17, 2007 | 04:20 PM
mikowen10's Avatar
I walked around it...buti am not sure where the sound is coming from....it seems to be coming from underneath the car....it's really loud and gets louder when you accelerate....but it sounds almost identical to one of those loud harleys. Thanks for the tips I'll have a mechanic check the exhaust.
Old May 17, 2007 | 05:35 PM
acetrebo's Avatar
The flex pipe is smack dab in the middle.
I'd bet your right ******* thats your problem.
Old May 17, 2007 | 06:09 PM
x1rider's Avatar
ORIGINAL: mikowen10
Did you pop the hood, maybe you have one of these under there!!!
Old May 17, 2007 | 06:40 PM
onepoint8tee's Avatar
ORIGINAL: acetrebo
haha... hmmmmmm... are you supposed to have more than one sack??? I better make a doc apppointment...
ya the flex pipe is the weakest part of the exhaust system other than the cat flange welds. I bet its one of the two, probably the flex pipe.
Old May 17, 2007 | 07:53 PM
david9999's Avatar
Flex pipe.
Old May 18, 2007 | 09:16 AM
mikowen10's Avatar
So i popped the hood and i think the noise was coming from the part of the exhaust that extends into the engine (the part that has a rusted metallic look). Would there be a flexpipe there ? Do you guys think I need to pehaps replace the entire exhaust ?
Old May 18, 2007 | 09:25 AM
ironman's Avatar
Not the entire exhasut, go to a mechanic, trusted mechanic if Possible and have them look under the car, if its teh Flex pipe will take him 5 secs to see it. Is your exhaust smeeling sweet when you are at idle at a light, does it smell like the harleys??? If yes then prob the flx pipe as its in front of the CAT.
