Is there a test to see if my maf is bad?
Old Mar 2, 2007 | 06:01 PM
The Bishop's Avatar
Default Is there a test to see if my maf is bad?
I am getting these codes,
p0102
p1425
p1472
Is there a way to check the maf to see if it's bad before I buy a new one for $300?
Old Mar 2, 2007 | 06:05 PM
MissionCtrl's Avatar
Default RE: Is there a test to see if my maf is bad?
sure...unplug it. if your car runs better, you need a new MAF
Old Mar 2, 2007 | 06:08 PM
techbod's Avatar
evap system form my data ( wiring shorting to ground ) EVAP canister purge valve
Old Mar 2, 2007 | 06:16 PM
onepoint8tee's Avatar
+1 for unplugging it and if it runs better then you know. If you end up needing a new one, check out www.ecstuning.com they seem to have the best prices, def not $300.
techbod's Avatar
# to check the MAF
[IMG]local://upfiles/12092/47207D535A9D40CDA538BDA6F25BD341.jpg[/IMG]
Old Mar 2, 2007 | 06:36 PM
The Bishop's Avatar
Ok. I unplugged it and no difference. The problem is that the car is in limp mode, so I can't really test it's performance that well. Any ideas?
Old Mar 2, 2007 | 06:38 PM
techbod's Avatar
VAG or unplug the ground cable for the battery for 1/2 hours to clear the code then test it
Old Mar 2, 2007 | 06:41 PM
The Bishop's Avatar
I had the codes cleared this morning, and those are the ones that came back. Unfortunitally I just ordered the vag cable yesterday so I don't have it yet. any ideas on what the short to grounds are about?
Old Mar 2, 2007 | 06:46 PM
techbod's Avatar
have you done any work on the engine?? consider any wire movement in that area
powersmokin
Apr 10, 2008 10:49 AM
oettinger1919
Feb 20, 2007 11:11 AM
The Bishop
Nov 30, 2006 06:03 PM
