Is there a test to see if my maf is bad?
Subscribe
Mar 2, 2007 | 06:01 PM
I am getting these codes,
p0102
p1425
p1472
Is there a way to check the maf to see if it's bad before I buy a new one for $300?
Reply
Mar 2, 2007 | 06:05 PM
RE: Is there a test to see if my maf is bad?
sure...unplug it. if your car runs better, you need a new MAF
Reply
Mar 2, 2007 | 06:08 PM
evap system form my data ( wiring shorting to ground ) EVAP canister purge valve
Reply
Mar 2, 2007 | 06:16 PM
+1 for unplugging it and if it runs better then you know. If you end up needing a new one, check out www.ecstuning.com they seem to have the best prices, def not $300.
Reply
# to check the MAF
[IMG]local://upfiles/12092/47207D535A9D40CDA538BDA6F25BD341.jpg[/IMG]
Reply
Mar 2, 2007 | 06:36 PM
Ok. I unplugged it and no difference. The problem is that the car is in limp mode, so I can't really test it's performance that well. Any ideas?
Reply
Mar 2, 2007 | 06:38 PM
VAG or unplug the ground cable for the battery for 1/2 hours to clear the code then test it
Reply
Mar 2, 2007 | 06:41 PM
I had the codes cleared this morning, and those are the ones that came back. Unfortunitally I just ordered the vag cable yesterday so I don't have it yet. any ideas on what the short to grounds are about?
Reply
Mar 2, 2007 | 06:46 PM
have you done any work on the engine?? consider any wire movement in that area
Reply
Subscribe
