thermostat
Old Dec 20, 2004 | 05:21 PM
flyboy's Avatar
Default thermostat
I'm working on my 2.8l putting a new timing belt and water pump on. Got it all back to gether last night, fired her up and watched as the temp soared up to the top, I noticed that the heater was blowing cold and I also had a shop fan blowing directly on the radiator, but it kept getting hotter. After getting frustrated and throwing some things around the garage i sat a thought about what I could be. All I can come up with is thermostat or airbubles.
Does anyone know where the thermostat is and also how the bleed the coolant system.
thanks
Old Dec 20, 2004 | 06:04 PM
Jestnomen's Avatar
6th Gear
Default RE: thermostat
Sorry I forgot to reply to your email!!
Yes you have air trapped. Do you have the heater on full blast/hot???
Unscrew and lift the coolant resoivoir about 4 inches.
Pull back the left (passenger side) hose that goes through the firewall until the small hole in the top of the hose is exposed.
Top off the coolant as needed.
When coolant squirts out of the hole, push the hose back on and lower the resoivoir.
You may need to do this a couple times to get all the air out.
Old Dec 20, 2004 | 07:35 PM
flyboy's Avatar
thanks alot! Oh and what do you think about the themostat?
Old Dec 20, 2004 | 08:12 PM
flyboy's Avatar
just did the hole in the heater hose thing and I think it was pretty full but anyway thats done now.
Old Dec 20, 2004 | 08:15 PM
Jestnomen's Avatar
6th Gear
Old Dec 20, 2004 | 08:19 PM
flyboy's Avatar
My thats a nice shiny new water pump (said with a lisp). Looks just like mine. Hey, thanks man, now I just have to look like a dumb *** taking my car apart again.
Old Dec 20, 2004 | 08:22 PM
Jestnomen's Avatar
6th Gear
have fun. Do you have the cam and crank holder tool?
Old Dec 20, 2004 | 08:26 PM
flyboy's Avatar
no but the belt is marked from the water pump escapad that I just went through. I was thinking as i did the belt at pump and pullys, "Hey, I should maybe change the themostat, what a marvalus Idea." but no, I had to put it all back to gether first. You know that how perfesonals do it, Bass Ackwards.
Old Dec 20, 2004 | 08:32 PM
flyboy's Avatar
by the way, do you fly, just wondering cus of you profile.
I fly kingair B90's 1100bhp and 2630 ft/tq. pretty bad ***.
Old Dec 20, 2004 | 08:44 PM
Jestnomen's Avatar
6th Gear
Did you also change the idle pully and tensioner? The engine is only as strong as the weekest link.
Yeah I have my private license. (cessna 172). Nothing special. I've been trying to get in a pilot slot for the Air Guard (c-130's).
