Thing that holds up the clutch pedal
Old Oct 31, 2006 | 08:42 PM
aRIf's Avatar
Default Thing that holds up the clutch pedal
There was an item that I saw before but do not remeber where. Small metal part can be installed under the clutch pedal so let you hit the clutch at the end point before.
What happen was, I do not need to push the clutch all the way down to change the gear. so I like to save some time with putting that stuff under the clutch pedal.
Any idea where can I find it ?
Old Oct 31, 2006 | 08:49 PM
captnmorgan's Avatar
Default RE: Thing that holds up the clutch pedal
wow ive never heard of those but damn i sure want one. my clutch is sooooooooooooooo long and it engages at the very last second...so i barely need to push at all.
if u find it pm me....better yet this could be my DIY for the weekend
Old Oct 31, 2006 | 08:52 PM
aRIf's Avatar
mine engages half the way down very smooth, so there is no point to go all the way down and lose some time..
Old Oct 31, 2006 | 08:56 PM
do u know if there is any place that does these legit?
Old Oct 31, 2006 | 08:59 PM
aRIf's Avatar
I don't know maybe I am just dreaming But I can do something like that with weling on a back of the pedal.
Old Oct 31, 2006 | 09:05 PM
wish i knew how to weld ahah
Old Oct 31, 2006 | 09:50 PM
chaos92287's Avatar
there was actually someone on here a few days ago that instead of that took the clutch pedal off and drilled another hole about 1.5" inches down from where the current one is and now his clutch engages closer to the floor. im assuming this would also shorten the length of the clutch travel as well.
found the link: https://www.audiforums.com/m_376650/tm.htm
Old Oct 31, 2006 | 09:59 PM
AudiCross's Avatar
you wouldnt need to weld. just attach a rubber pad to the back of the clutch. wire tie it ort something.
Old Oct 31, 2006 | 10:37 PM
BadLuckAudi's Avatar
just duct tape a rock behind it
Old Oct 31, 2006 | 11:48 PM
kpatz's Avatar
Whatever you do, you'll need to make sure the pedal still hits the starter switch when you push it down, or else you won't be able to start the engine. (on my '02 anyway, maybe the 97-99 models don't have this switch). Also, there's a switch that engages at the top of the pedal travel that disengages the cruise control, you'll need to make sure that switch is still activated by the pedal when you let it up, or the cruise control won't work.
