Those with GIAC
Old Dec 14, 2006 | 04:05 PM
new2me's Avatar
Default Those with GIAC
I was wondering if your boost levels change depending on what gear you are in.
Ex: 1st 10psi
2nd 15psi
3rd 20psi
4th 20psi
5th 20psi
Old Dec 14, 2006 | 04:20 PM
onepoint8tee's Avatar
Default RE: Those with GIAC
I normally boost 18+ in all gears. Sometimes i see a drop off to 15psi, but thats usually in 3rd gear + close to redline.
Old Dec 14, 2006 | 04:32 PM
JohnnyBravoA4's Avatar
i use to get less boost in first gear at wot like 15, but held 18 as well
Old Dec 14, 2006 | 04:38 PM
NuYorka103185's Avatar
I dont have a boost guage but I can tell you there is much more boost from second on just from the pull and the sound of the turbo. Damn turbo lag!!!!
Old Dec 14, 2006 | 05:23 PM
18T's Avatar
18T
i couldnt even tell you. my boost guage reads 0 at all times now since the line is pinched. still havent fixed it.
Old Dec 14, 2006 | 06:06 PM
AudiTurbo's Avatar
I have a 981.8tqm
1st gear- 10 or so
2nd- up to 15 or so
3rd- 18 or so....then drops to 8 psi by redline and so on with the gears....
sounds bad?>
Old Dec 14, 2006 | 06:10 PM
new2me's Avatar
From what info im seeing here is that its ok that the peak psi is different in different gears. The reason i am asking here is to compare MTM to GIAC since i cant get a hold of the only MTM dealer in the USA. I guess this could also be a good trouble shooting guide for future problems.
Old Dec 14, 2006 | 06:14 PM
As far as I know, MTM is best for use with the S4. I dont think they have as great claims or peak #'s as GIAC or APR for the A4.
Old Dec 14, 2006 | 06:15 PM
18T's Avatar
18T
revo spanks giac ahhaha ive had both and revo MOVES mannn...
Old Dec 14, 2006 | 06:19 PM
Amze's Avatar
Hmm... Pretty sure ima try en get REVO for my B6.. Well see if theres a local dealer for it
