Throttle is cutting in and out in boost range... *UPDATED* TESTED N75 TODAY!
Old Jul 22, 2007 | 01:42 AM
Audi_Skydiver's Avatar
Default RE: Yet another problem... I am really getting pissed now! BOOSTING PROBLEMS!
Ok cool. Thanks! I will buy an MBC tomorrow.
Josh
Old Jul 22, 2007 | 11:14 AM
onepoint8tee's Avatar
Your n75 might be bad, but it could be something else. If you dont have any fault codes, buy a volt meter and test your n75. Search for what the correct reading should be. Dont just start guessing and replacing parts at random. If you do get a mbc, dont be an idiot and crank it up without proper tuning. Your ecu wont adapt for the added boost like 00+ engines do with the diode mod/mbc.
And speaking of that: https://www.audiforums.com/m_583205/mpage_3/tm.htm
Old Jul 22, 2007 | 12:52 PM
OK, I will do that. And also if it is not the N75, what else could it be?
josh
Old Jul 22, 2007 | 01:37 PM
96audia4's Avatar
If you remove the N75 and check the resistance between the two pins, it should be 25-35 ohms. Thats the only test I could find that doesn't require some special equipment other than a multimeter.
Old Jul 23, 2007 | 08:47 PM
OK, so I am still at a loss here. I need to get this fixed and I can't figure out what is going on. No codes and the N75 seems to be bad. My boost is REALLY inconsistent now. Like i can hit the gas and keep my RPMs in the same area holding xPSI and then randomly my boost will just jump up to a much higher amount without me actually pressing the gas peddle harder. It is almost becoming a special skill to drive it with out it jerking around a bunch. If it's not the N75 what else could it be?
Josh
Old Jul 23, 2007 | 08:52 PM
Do you own a multimeter/voltmeter? The are pretty cheap, it would be a good investment.
Old Jul 23, 2007 | 09:13 PM
I am going to pick one of those up here tonight or tomorrow.
Josh
Old Jul 23, 2007 | 09:27 PM
  #18
Im surprised you dont have any fault codes though. I bet its the n75, but it might not be.. Youd probably be kind of upset if you spent $70+ on a new one and it didnt fix the problem though.
Old Jul 23, 2007 | 11:29 PM
  #19
If I just got an MBC and bypassed the N75 would that work?
Josh
Old Jul 24, 2007 | 06:51 PM
  #20
OK, so i just tested the N75 with the voltmeter and I got a few different readings. At one point it was jumping around from 55-120 and then it leveled out at 31.5. I am so confused. I also rented a code scanner and have scanned it multiple times and I still do not get any codes. Any other ideas???
Josh
