Ticking - Lifters - Sludge?
Old Sep 28, 2006 | 10:14 PM
redgsr's Avatar
Default Ticking - Lifters - Sludge?
I have been doing a bunch of reading.
I am looking at a 2000 a4 1.8q with 55k one owner.
Only noticealbe problem is ticking noise from (facing the car) right side mid engine point.
I have narrowed it down just from reading to either valves or lifters.
It is worth paying around 9-10k for a car that is making this noise? Miles are pretty low for a 2000 so I assume it's not something else major going on.
I read some people use a solvent to clean the sludge out and it semi works.
Next question is there a valve adjustment maintence on these cars, like a scheluded maintence?
Thanks
Old Sep 29, 2006 | 05:33 AM
sandman's Avatar
Default RE: Ticking - Lifters - Sludge?
is there milky stuff on your oil cap.
Old Sep 29, 2006 | 11:05 AM
dafrazi's Avatar
Almost all 1.8T cars have a little ticking.
Old Sep 29, 2006 | 12:09 PM
smokeU's Avatar
tack on another 850 to 1000 to that price cause you're due for the t-belt
Old Sep 29, 2006 | 04:14 PM
techbod's Avatar
in the UK sludge was eradicated by synthetic oils and never heard of here for many years ( unless you don't change the oil and filter when you should ) then you get what you should expect
Old Sep 29, 2006 | 04:19 PM
wood_e's Avatar
Easy insurance... if you buy it, drop the oil pan and clean out the pickup screen, then run some seafoam through the crankcase.
Old Sep 29, 2006 | 04:21 PM
techbod's Avatar
lets look at this problem in a different way, a 5 year old car service to the book has 5,000 miles on the clock old folk like me don't drive much/ same car with 50,000 on the clock and service history, synthetic oil and regular filter changes in both cases ((( which car would you buy )))
Old Sep 29, 2006 | 04:45 PM
redgsr's Avatar
On a scale of 1-10 how hard is it to clean out the screen in the oil pan?
I assume it's not that big of a deal but I have never owned an audi so?
Old Sep 29, 2006 | 04:47 PM
techbod's Avatar
if your tech orientated then 5 if not I would say 9
Old Sep 29, 2006 | 05:38 PM
redgsr's Avatar
Really?
What makes this so hard?
Is there something blocking access to the oil pan?
I have been a honda guy for years and the pan is just a few bolts away from comming off.
