Tie rod end replacement
Old Apr 20, 2005 | 06:39 PM
jukeit's Avatar
Default Tie rod end replacement
Yola
My 98 A4 quattro is wicked scary on rutted roads. Thanks to a bit of troubleshooting and another post on this board, I'm going to replace my tie rod ends to fix the problem. I have a service manual and don't expect to hit any snags, but I'm a rookie when it comes to car repair. If anyone has any advice on the replacement (potential problems, common mistakes, etc.) please let me know. Thanks!
Old Apr 20, 2005 | 06:50 PM
Jestnomen's Avatar
6th Gear
Default RE: Tie rod end replacement
Have you seen this?
Old Apr 20, 2005 | 06:53 PM
clconversion's Avatar
this is probley the only good thing about Audi world is the tech articles
Old Apr 20, 2005 | 07:17 PM
BFlan2001's Avatar
ORIGINAL: clconversion
yea, their tech section is pretty amazing....we need to make ours bigger!
Old Apr 20, 2005 | 07:18 PM
Jestnomen's Avatar
6th Gear
Well hop to it then!
Old Apr 20, 2005 | 07:22 PM
BFlan2001's Avatar
haha, i'm workin on it! i try to get people to make a write-up whenever i see someone doing their own mods/repairs...someday we'll take over aw....someday..
Old Apr 20, 2005 | 08:10 PM
jukeit's Avatar
I haven't seen that. Mine look about as damaged as the one in the pic. Thanks for the link, it's exactly what I need.
Old May 2, 2005 | 12:54 PM
jukeit's Avatar
So I replaced the tie rod ends over the weekend. First one took about an hour. Second one took about 20 min. Thanks for pointing me to the procedure Jest; it was much better than the Haynes manual procedures.
This took care of my splashy steering problem. I forgot how much fun this car is to drive.
Old May 3, 2005 | 12:46 AM
Shaunp05's Avatar
Did you take her for an Alignment ?
Old May 3, 2005 | 12:49 PM
jukeit's Avatar
The procedure link in this post and the Haynes manual procedure both gave the heads-up to carefully measure the distance between the lock nut and the tie rod end. I did this with a good degree of accuracy. I've driven a couple of hundred miles (long commute) since the replacement and haven't noticed any alignment problems. I figured I would check for abnormal tire wear the next time I rotate them. Is there anything else I should look for to verify my alignment is ok? I would like to skip paying for an alignment if possible. Is there anything I could F up if the alignment is slightly off and I don't realize it? Thanks.
