Which Timing Belt to buy and does pulley work?
Old Apr 13, 2007 | 12:12 PM
DavidTurbo's Avatar
Default Which Timing Belt to buy and does pulley work?
I need to change my Timing belt and was thinking about buying the ECS ultimate belt kit. Is there another kit that's being offered elsewhere that might be cheaper but just as good? Also I was debating on wether to get the lightweight crank pulley. Is it worth it? Can you really tell the difference with the lighter pulley or is it just a waste of money? Thanks for your input
Old Apr 13, 2007 | 12:45 PM
zoti's Avatar
Default RE: Which Timing Belt to buy and does pulley work?
http://www.dieselgeek.com/Detail.bok?no=306
Old Apr 13, 2007 | 06:34 PM
acetrebo's Avatar
The only way to know if its just as good, is to compare the parts between the two kits.
I got mine elsewhere instead of ecs because it was cheaper, and the kit was fine. As long as it has all the neccesary components, you should be fine.
Old Apr 13, 2007 | 06:43 PM
techbod's Avatar
your car dosnt warrant this upgrade but a worthy upgrade never the less and made by Gates which is the best in the world so go for it
Old Apr 13, 2007 | 07:32 PM
timbo108's Avatar
I bought the dieselgeek kit. Nice parts, even my mechanic commented about the quality. I think it was $260 well spent. I've heard the underdrive pulleys don't get you much.
Old Apr 13, 2007 | 10:35 PM
david9999's Avatar
If you are looking for the extra 0.01 sec off the line, a lightweight or underdrive pully will give you that extra edge. For most of us, it isn't worth it.
Old Apr 13, 2007 | 10:40 PM
Flip's Avatar
I would just stick to the OEM timing belt kit imho.
Old Apr 15, 2007 | 08:15 PM
DavidTurbo's Avatar
ORIGINAL: Flip
By OEM kit you mean from the dealer?
Old Apr 15, 2007 | 10:31 PM
david9999's Avatar
ECS kit with G12 coolant.
Old Apr 16, 2007 | 01:14 AM
A4Rollin's Avatar
i got a timing belt kit just from audi and it was $320 w/ everything
