TIMING BELT SNAPPED at IDLE !!!!!
Old Oct 18, 2007 | 08:34 AM
crayzdavy's Avatar
Default RE: TIMING BELT SNAPPED at IDLE !!!!!
My buddy has the alignment tool and everything will be lined up TDC.
Old Oct 18, 2007 | 09:52 AM
khj677turbo's Avatar
Happened to my friends ford. Car was fine. I hope your as lucky as she was.
Old Oct 18, 2007 | 10:08 AM
ironman's Avatar
ford TB snapping is totally diff then an Audi fords arent interferance engines ive popped 2 of them on my chevies im like whoooa 300 to fix Audi you are totally fucked
Old Oct 18, 2007 | 10:57 AM
crayzdavy's Avatar
Very true ironman. My fiance's toyota snapped going 75. Relatively cheap fix and all was fine. The Audi interference engine is completely different. My fingers are crossed.
The front end is off the car.
I'll let you know how it all goes later on today.
Old Oct 18, 2007 | 11:08 AM
AudiBama's Avatar
good luck[sm=groupwave.gif][sm=wootwoot.gif]
Old Oct 18, 2007 | 12:19 PM
The Russian's Avatar
rootin for ya, would hate to see an audi go down because of that
Old Oct 18, 2007 | 12:49 PM
SAudi's Avatar
http://forums.audiworld.com/a4/msgs/2499586.phtml
hopefully this helps. reall i havent heard of many V6 breaking abelt espacially in a 12v. hopefully the best case is that the belt just needs replacing and for you worst case scenario (lets hope not) its just a few bent valves.
Old Oct 20, 2007 | 04:57 PM
  #18
crayzdavy's Avatar
UPDATE
It's fixed!!!!! No damage!!!! YEAH BABY!!!!
Old Oct 20, 2007 | 05:07 PM
  #19
qUaTtRoA4's Avatar
good to hear!
congratulations!
Old Oct 20, 2007 | 05:16 PM
  #20
cincyTT's Avatar
I'm make believe
ORIGINAL: crayzdavy
UPDATE
Did you actually check the valves? Even at idle the pistons have plenty of force to bend a valve. So im hoping that you actually took of the heads and checked the pistons and valves. If not, you could be causing more damage in the long run
