Timing belt, and what else?
Old Dec 4, 2006 | 04:48 PM
Riko's Avatar
Default Timing belt, and what else?
I am going to have my timing belt replaced, and heard that it is a lot of labor and they have to basically dismount the entire front end. So i figured while the
mechanic was down there or in there he could replace other things as well so i dont have to pay all that labor again. My 2001 1.8T has about 100K. Are there any other serivces
i should have the mechanic perform before he puts it all back together?
Thanks-
Old Dec 4, 2006 | 04:54 PM
techbod's Avatar
Default RE: Timing belt, and what else?
they will charge you regardless for each item fitted, timing belt/ tensioner/ serpentine belt and tensioner/ water pump/ coolant/ oil and filter, check around for the best price and even provide your own parts to cut the cost ( Audi wont do that )
Old Dec 4, 2006 | 05:46 PM
CRAZYHAWK's Avatar
An independent mechanic should charge around $750
for all the above.
Old Dec 4, 2006 | 06:03 PM
rayveedub's Avatar
dont know where you are but i do that service for 500 bucks. also do some denso iridiums. i love those plugs.
Old Dec 4, 2006 | 07:11 PM
BaconBait's Avatar
Upgrade your snub mount also.
Old Dec 9, 2006 | 03:50 PM
Riko's Avatar
I will def have them do the timing belt/ tensioner/ serpentine belt and tensioner/ water pump/ coolant/ oil and filter.
But what is a snub mount?
Also what about denso iridiums?
Wouldnt it cost me less labor in hours if they changed all this while doing the timming belt? Therefore reduce the total cost?
Old Dec 9, 2006 | 05:17 PM
TheJazz7's Avatar
"Wouldnt it cost me less labor in hours if they changed all this while doing the timming belt? Therefore reduce the total cost? "
Yeah, that's the idea. Do all this in one sitting.
Old Dec 9, 2006 | 08:43 PM
david9999's Avatar
Front engine cam seals
Old Dec 10, 2006 | 12:31 PM
midohioguy's Avatar
this should have everything you need:
http://cgi.ebay.com/ebaymotors/New-A...spagenameZWDVW
has anyone ever bought one off ebay before? how did it work out?
Old Dec 10, 2006 | 02:25 PM
BaconBait's Avatar
ORIGINAL: Riko
It's a hard rubber piece on the front of the engine. An aftermarket upgrade (about $50) will decrease the engine movement when accelerating and decelerating.
