tiptronic does not work help!!
Old Jul 1, 2006 | 09:27 PM
nyaudia498's Avatar
Default tiptronic does not work help!!
just bought 98 audi a4 and the tiptronic does not work what should i look for to fix it
Old Jul 2, 2006 | 03:00 AM
TheJazz7's Avatar
Default RE: tiptronic does not work help!!
Did you buy it from a dealership? If so, definitely take it back to them pronto.
If you bought it from a private seller, see if you have any recourse with them to have this issue addressed and have you compesated for the cost of fixing it. But more likely, you're SOL and will get stuck paying to fix it.
What exactly is wrong with it?
If you're paying for it, definitely don't take it to the dealership, it'll prob be pretty expensive. Find a repuatable mechanic that SPECIALIZES IN EUROPEAN CARS, preferrably German cars like Audi and BMW....this is not a job for Jiffy Lube.
Good luck.
Old Jul 2, 2006 | 04:50 AM
ejc317's Avatar
what do u mean by doesn't work tho?
Like the manual mode doesn't work or you can't drive at all.
If it's just manual then it's an issue with the tip control probably ... which is cheaper than the whole transmission
Old Jul 2, 2006 | 09:00 AM
david9999's Avatar
More details please.
Another reason to have a qualified mechanic check the car before you buy.
Old Jul 2, 2006 | 01:42 PM
nyaudia498's Avatar
it drives perfectly fine and the transmission shifts real good in the regular mode, but when i put it over to triptronic it doesnt do anything when i shift up and down
Old Jul 2, 2006 | 01:46 PM
david9999's Avatar
Probably the sensor in the shifter that has been bumped out of place.
indie.ianjones
Jun 17, 2009 11:32 PM
indie.ianjones
Jun 10, 2009 01:34 AM
ashezplayboy
Dec 22, 2008 11:50 AM
YFZFourFifty
Jul 25, 2005 01:56 AM
