tire circumference difference?
Old Aug 16, 2005 | 01:53 PM
laxhuskie9's Avatar
Default tire circumference difference?
i recently had a shop tell me that i need to replace my front tires because their circumference was significantly less than the rears, and that could screw up my differential. now i know that the fronts will wear more but does anyone know what the actual maximum difference should be...or even heard of this? thanks
Old Aug 16, 2005 | 02:45 PM
InsaneHatter's Avatar
Default RE: tire circumference difference?
If you have quattro this can screw it up. Based on the fact that if your circumference is smaller the wheel must spin faster to go the same speed as a wheel with larger circumference. That being said, your quattro senses different wheel speeds and it Mooks up....
Thats the bottom line. I dont know what the maximum difference is though.... 1/4" ?
Old Aug 16, 2005 | 03:17 PM
juju4uofa's Avatar
BS!!! There is not enough tread on a tire to make a difference. No one can concince me that if you have new tires in the rear and bald tires in the front that it'll matter. There is more of a difference caused by the weight biass in our cars than you'd ever tell from treadwear or if a tire has less pressure than another. He justs wants your money.
Old Aug 16, 2005 | 03:23 PM
This is true, there is not that much tread to screw your differential.
But tire circumference does matter.
Old Aug 16, 2005 | 04:20 PM
laxhuskie9's Avatar
thanks, that's good to know seeing as i didn't wanna half to spend another $300 or so on 2 new tires...
Old Aug 16, 2005 | 06:14 PM
CRAZYHAWK's Avatar
As long as the tires have close diameters, same tread depth, left and right you're OK. You should use the same model and size tire all around. Front to rear wear is not important.
Jack_Tauson_Sr
Jan 28, 2015 10:31 PM
matthayzon89
Aug 10, 2013 12:14 AM
fidelite
Jun 24, 2008 02:06 PM
sirfalconx
Nov 22, 2007 09:27 AM
seaurchin99
May 26, 2005 11:39 PM
