Sponsored by:
Sponsored by:
tranny fluid change...
Old 08-14-2006, 04:40 PM
DENIS415's Avatar
Default tranny fluid change...
so i wanna change my tranny fluid at 125,000 miles because it has never been changed......i know where to drain the fluid, but does anyone know where the holes are to fill it back up(PICS) and how much fluid it needs for a refill....im trying to do that right now so if someone can help me i would appreciate it...
Old 08-14-2006, 05:48 PM
zat0rsk1's Avatar
Default RE: tranny fluid change...
I would like to know too =)
Old 08-14-2006, 06:24 PM
Adam@mvp's Avatar
not sure but does it have a drain plug and a plug to show if its full or not should be above the other plug if so.
if it is there then you will have to use that plug to fill the tranny
Old 08-14-2006, 06:31 PM
it doesn't have a drain plug you use the same plug to fill and drain ( you have to siphon the old oil out ) then fill till it pours out then bolt it up
Old 08-14-2006, 06:45 PM
DENIS415's Avatar
how many quarts tho do i have to put pack in....for the tranny?
Old 08-14-2006, 06:55 PM
UK figures only are 2.5/2.7 litres but you fill till it comes out of the hole then you know its full
Old 08-14-2006, 06:56 PM
I assume its a 1.8T manual tranny??
Old 08-14-2006, 07:00 PM
DENIS415's Avatar
99 1.8T tiptronic
Old 08-14-2006, 07:16 PM
ok so its an automatic then then its 2.6 liters drain and refill, move the shift lever back and forth a few times it sounds like the inhibitor has kicked in check all fuses
Old 08-14-2006, 07:25 PM
DENIS415's Avatar
can you explain more about the inhibitor...not sure i understand what youre trying to tell me...srry....
Quick Reply: tranny fluid change...
