Tranny Oil Change Writeup
Old Dec 21, 2005 | 07:09 PM
luvin_the_rings's Avatar
Default Tranny Oil Change Writeup
hey guys, just finished changin my tranny oil.
getting the drain plug out was a breeze with the germanautoparts.com drain plug and fill plug tool seen here
only 25 buks and it does the tranny, and oil pan plugs.
the only pita was getting the fill plug off, i had to bust out my monster wrench to get enough torque to get that beast broken. That was when i realized that i was a proballly a good idea to change the oil because it has been in there forever.
the soap that i use to take a shower comes in a bottle that has a hand pump on it, and it holds a good quart and a half of soap (thanks to costco), so i just poured all the soap out, rinsed it so ALL the soap was out, let it dry, and it worked perfecly, i just put the nozzle into the drain plug and began pumping. it took me maby 15 minz to get all 3 quarts in there
The shifts are like butter now, i cant feel any metal to metal contact within the gears, and the syncs are maching up like crazy, downshifting from 3 to 2 is almost as fast as upshifting from 2 to 3, which is awsome.
i used Coastal 75 w90, i was too cheap to buy the mobil 1 stuff. I was at D1 last weekend and saw some 75 w90 full synthetic by this company called Torco for 12 buks a quart!! It was meant for the D1 cars that run a good 500 hp and are shifting like crazy all during thier runs. i can only imagine how smooth the shifts would be if i had baught that stuff.
anyway, i highly reccomend this to anybody who drives a 5 speed. it makes the shifts way more fun, and easy, and it seems like when you are rolling in neutral or somthing, the oil makes you roll much faster.
i read over how to do it right here on AudiForums DIY section by Sandman
Old Dec 21, 2005 | 07:14 PM
onepoint8tee's Avatar
Default RE: Tranny Oil Change Writeup
ORIGINAL: luvin_the_rings
Good job i should do mine.
Old Dec 21, 2005 | 09:08 PM
jja2.8's Avatar
yeah that wright up inspired me to change mine also.
did you use 75-90 gl4?
everything i read about gl5 says it will eat away at brass synros.
Old Dec 21, 2005 | 10:00 PM
yea gl4 is reccommended by audi
the same place where i got the tool has oil that works perfectly for audi's
Old Dec 22, 2005 | 02:07 AM
david9999's Avatar
Just remember, always remove the fill plug first. If you drain your oil and your fill plug is frozen in place, you're F'd
Old Dec 22, 2005 | 05:06 AM
dang... good call man... didnt think of that
Old Dec 22, 2005 | 05:09 PM
brrman's Avatar
I $5 fluid pump will do a better job that your soap bottle. But thats some ingenuity you used. Good job.
Old Dec 22, 2005 | 10:50 PM
brent07's Avatar
is it true you need a vagcom to do it ... b/c i dont have one and i want to do it
Old Dec 22, 2005 | 11:35 PM
sandman's Avatar
no you dont. just drain it. look in the DIY section, it tells how to do it.
Old Dec 22, 2005 | 11:42 PM
brent07's Avatar
alright ... thanks ... have you guys ever used royal purple ? ... i'm gonna give that a try
