transmission control unit question!!!???
Old Jan 30, 2008 | 06:04 PM
kakashisan's Avatar
Default transmission control unit question!!!???
well i know that my car needs a tcu replace so do they need to program this unit or can i just buy it straight from the dealer ship and have some one else replace it for me, at the dealer they are trying to charge me 2600 for everything so i would like to know if there is a special requirement to replace it
Old Jan 30, 2008 | 11:28 PM
dankhound's Avatar
Default RE: transmission control unit question!!!???
Depends. Most of the time the coding of the module out of the box will work just fine. Other times the coding needs to be changed to match the vehicle. In any case the coding of the module can be performed with a vagcom.
Old Jan 31, 2008 | 01:29 PM
SLVR99A4's Avatar
How do you know you have a faulty TCU? What wasyour car's symptoms? The reason I ask is because soon I too will be replacing my TCU to see if it is the cause of my on going tranny problems.
Old Jan 31, 2008 | 04:30 PM
kakashisan's Avatar
well the reason is because i took my car over to the dealership to get a diagnosis and that's what it came to be, also my gears flash it doesn't show u which gear are you in, tiptronic doesn't work
tunaoue
Apr 27, 2011 01:57 AM
BAVARIANM
Apr 10, 2010 12:54 AM
peeties
Aug 25, 2009 01:05 PM
dgirlsdemsugar
Oct 26, 2008 11:43 PM
kakashisan
Feb 3, 2008 06:45 PM
