transmission seal bell housing leak
Subscribe
Oct 17, 2007 | 09:29 PM
A4 1999.5 1.8T Q, AEB engine, AT (DVT), 99K miles. I pulled the engine to do a swap/rebuild (blown turbo for sure and probably sludge?) and found "oil/tranny fluid" in the bell housing and inside the Torque Converter. I can see fluid settled under tranny shaft too. Is this a simple seal replacement? If so how hard is it to replace? If this front seal is bad, what else might neeed replaced?
All of a sudden, its a project car!
Thanks!
Reply
Oct 17, 2007 | 09:34 PM
RE: transmission seal bell housing leak
Its the torque converter seal, you can replace that but you need the correct install tool to press it in.
You can buy it at the dealer for about $20 or so.
Reply
Oct 17, 2007 | 09:49 PM
Thanks! Should I be worried about seals at the other end of the tranny now, or wait until I see a wet spot?
Reply
Oct 17, 2007 | 09:51 PM
No the tail housing seal can easilly be replaced by taking out the prop shaft and popping it out with a screwdriver or pry bar. I would wait onthat seal.
Reply
Oct 17, 2007 | 10:01 PM
Any tips for getting the fluid out of the torque converter?
Reply
Oct 17, 2007 | 10:06 PM
Pull that **** straight out and turn it upsidown LOL.
Reply
Oct 17, 2007 | 10:12 PM
Yea, I was afraid it was goning to be that "easy". It reminds me of trying to get all the oil out of an oil filter. Step 1: Turn it upside down... Step 2: repeat step 1 a hundred times.
Reply
Oct 17, 2007 | 10:13 PM
u can also stick a pump in there and rotate the sucker will pumpin.
Reply
Oct 17, 2007 | 10:32 PM
A pump? Hum... That gives me an idea that just might save the planet!
Reply
Oct 17, 2007 | 10:36 PM
lol
Reply
Subscribe
