transmission seal bell housing leak
Old Oct 17, 2007 | 09:29 PM
Tlag's Avatar
Default transmission seal bell housing leak
A4 1999.5 1.8T Q, AEB engine, AT (DVT), 99K miles. I pulled the engine to do a swap/rebuild (blown turbo for sure and probably sludge?) and found "oil/tranny fluid" in the bell housing and inside the Torque Converter. I can see fluid settled under tranny shaft too. Is this a simple seal replacement? If so how hard is it to replace? If this front seal is bad, what else might neeed replaced?
All of a sudden, its a project car!
Thanks!
Old Oct 17, 2007 | 09:34 PM
auditech79's Avatar
Default RE: transmission seal bell housing leak
Its the torque converter seal, you can replace that but you need the correct install tool to press it in.
You can buy it at the dealer for about $20 or so.
Old Oct 17, 2007 | 09:49 PM
Tlag's Avatar
Thanks! Should I be worried about seals at the other end of the tranny now, or wait until I see a wet spot?
Old Oct 17, 2007 | 09:51 PM
auditech79's Avatar
No the tail housing seal can easilly be replaced by taking out the prop shaft and popping it out with a screwdriver or pry bar. I would wait onthat seal.
Old Oct 17, 2007 | 10:01 PM
Tlag's Avatar
Any tips for getting the fluid out of the torque converter?
Old Oct 17, 2007 | 10:06 PM
auditech79's Avatar
Pull that **** straight out and turn it upsidown LOL.
Old Oct 17, 2007 | 10:12 PM
Tlag's Avatar
Yea, I was afraid it was goning to be that "easy". It reminds me of trying to get all the oil out of an oil filter. Step 1: Turn it upside down... Step 2: repeat step 1 a hundred times.
Old Oct 17, 2007 | 10:13 PM
hiwords's Avatar
u can also stick a pump in there and rotate the sucker will pumpin.
Old Oct 17, 2007 | 10:32 PM
Tlag's Avatar
A pump? Hum... That gives me an idea that just might save the planet!
Old Oct 17, 2007 | 10:36 PM
hiwords's Avatar
lol
quattrolove
Sep 27, 2010 06:42 PM
bandmax
Jan 13, 2009 10:03 PM
AWD4g63
May 19, 2008 09:51 PM
strickland.j
Feb 11, 2008 11:42 PM
shovin
Mar 14, 2007 07:03 PM
