Transmission Service
Old Sep 7, 2007 | 10:14 PM
lboudreau's Avatar
Default Transmission Service
So I am at the point in my transmission fluid change where I have removed all the old fluid and have the pan and filter off of the transmission. So I have a few quesitons for those with Bently manuals (if the information is there) How much fluid is supposed to go back in (as per documentation). Does it REALLY matter if I don't monitor transmission temp, and if it does, can I just use a thermometre in there? And when I'm filling it back up I have to fill the pan till it overflows then start the engine and get someone to go through all the gears about 30 seconds each while I keep filling it (always keeps a slight overflow) correct?
Any help would be great. I'm sure it will be ok as long as I get the fluid it needs in there. I'm sure anything is better then the crap that came out! [:'(]
Old Sep 8, 2007 | 11:28 AM
2k S4's Avatar
Default RE: Transmission Service
I take it that your car is a TIP?
You fill it until, the fluid comes out of the fill hole, start up the car, go through all the gears, go back to N & fill till the fluid comes out, put the plug back in. Yea, the engine & trans should be warm. The best way is to get the car on 4 jack stands, & run the engine in gear for 5-10min.
Old Sep 8, 2007 | 12:53 PM
jason23silver1's Avatar
I have a 2000 A6 Quattro with 132000 miles on it. The transmission fluid has never been changed. should i change the fluid.
Old Sep 8, 2007 | 02:17 PM
2k S4's Avatar
ORIGINAL: jason23silver1
I would.
Old Sep 8, 2007 | 04:56 PM
lboudreau's Avatar
Thanks 2k S4,
I finished the job. After all was said and done the tranny took 7.3 qts.
I'm assuming thats what it needed. Shifts way smoother now!
Old Sep 8, 2007 | 05:57 PM
rally2's Avatar
Good post!
I'm doing factory tranny oil & filter on my 99 tip.
Old Sep 9, 2007 | 06:55 PM
lboudreau's Avatar
Just an update on my tranny. I hear a hiss noise comming from somwhere when I'm in reverse. I don't know if this is normal. I don't remember hearing it before the fluid change but I might not have been listening for it before. Its not very loud, and it doesn't start the second you put it in reverse, only about a second after it engages. if anyone has any insight that would be great!
Old Sep 9, 2007 | 09:28 PM
lboudreau's Avatar
bump,
anybody?
Old Sep 9, 2007 | 11:07 PM
rally2's Avatar
Put the car back up on stands or a lift level and hot and recheck the fluid level.
Did you buy trannyoil right from the dealer?
Old Sep 10, 2007 | 06:03 AM
david9999's Avatar
Tranny should NOT be hot, With a COLD start, taake it once around the block and then check the level.
