Trouble with A4 1.8TQM
Old Oct 24, 2005 | 09:31 PM
99A4NOW's Avatar
Default Trouble with A4 1.8TQM
Sorry for the seperate post here, but looks like more people surfing around this forum. Mechanical experience may be what I need.
See this thread: https://www.audiforums.com/m_156087/tm.htm
Thanks
Old Oct 24, 2005 | 09:38 PM
germancarmaniac's Avatar
Default RE: Trouble with A4 1.8TQM
try a 3 part fuel injection cleaning system. valvoline has a good one but it its about 70 bucks at the store. Then try the fuel filter and at the worst a fuel pump
Old Oct 24, 2005 | 11:31 PM
TomRitt's Avatar
sounds more like a surging issue than a fuel injection issues although I could be wrong. Check the vac lines, mainly the unes around the n75/wastegate area, and the one coming off the front of the manifold
Old Oct 24, 2005 | 11:47 PM
Shaunp05's Avatar
If she is breaking down it has to be either fuel problem or Spark
does it kinda like fall flat on her face ?
like lose power then pick up ?
you can try and load up the engine and feel if she
does it I need more infor on the problem
ButI would be looking at the M.A.F. and Spark before anything els
Old Oct 25, 2005 | 09:53 PM
99A4NOW's Avatar
Ok, thanks for the replies so far. When I get back to the car this weekend I will try to get better data. RPM range where the problem exist seems limited to 1500 to 3000. Its not what I would call a loss of power, it more like several slight hesitations in a row.. very quick, and then smooths out again as the RPMs go above 3K. What else should I look for to tell you? I will check (maybe replace) the spark plugs too.
Thanks again.
Old Sep 11, 2006 | 07:41 PM
luke30's Avatar
I am having the exact same problem, I see this was posted a year ago, have you solved the problem?
AudiRy05
Nov 17, 2008 02:49 PM
loejsirrah
Jun 16, 2008 12:13 PM
robes
Oct 11, 2006 02:57 AM
Snowboardr424
May 11, 2006 11:57 PM
Nick Robinson
Jan 27, 2003 10:20 PM
