Trouble Code P0118
Old Mar 6, 2006 | 09:09 PM
doitagaindave's Avatar
Default Trouble Code P0118
My wife brought her 98 A4 1.8t in for emissions check. It failed because the check engine light was on. They don't even do a tailpipe
check. Anyway the fault code was P0118 Engine Coolant Temperature Circuit High Input. Can anyone tell me what sensor this might
be. I change the Blue coolant sensor about 2 years ago.
Old Mar 6, 2006 | 10:22 PM
CRAZYHAWK's Avatar
Default RE: Trouble Code P0118
It may need changing again.
Old Mar 8, 2006 | 01:24 AM
dankhound's Avatar
As stated above, it may need to be replaced again or you may have a wiring issue. Is it a hard fault or sporadic? If its sporadic i would just clear it and retest.
Old Mar 8, 2006 | 07:35 PM
It's sporatic it's on for a week or two then it goes away. I was wondering if there is another sensor.
Thanks I'll reset and forget it.
Old Mar 8, 2006 | 07:56 PM
mjvss21's Avatar
well if the only reason it failed is because the light was on then clear it drive over there and pass then if it proves to be more hassle then its worth forget it.
Old Mar 8, 2006 | 09:21 PM
Thanks Guys,
I can't believe they failed it for that. If thats the only coolant sensor then I guess I'll change it again.
Just like the name says "doitagaindave"
Old Mar 26, 2007 | 02:41 PM
youngturky's Avatar
go to autozone. tell them you need a diagnostic, the same codewill show up on their machine and just order the new part its 7.99$
Old Mar 26, 2007 | 02:57 PM
techbod's Avatar
# change the temp sender and the thermostat
[IMG]local://upfiles/12092/08847545F342443CAA5E244675662FAE.jpg[/IMG]
[IMG]local://upfiles/12092/54482C27E47B40F9B06D2BA014BB6040.jpg[/IMG]
jj2345
Mar 18, 2009 10:20 PM
kwaskow
Mar 18, 2009 01:19 PM
steveurkel
May 7, 2008 08:29 PM
i3uddha
Jun 20, 2006 06:19 AM
ryanbelcher
Aug 3, 2005 09:46 PM
