trouble starting 97 1.9tdi
Old Sep 11, 2006 | 08:40 AM
markf497's Avatar
Default trouble starting 97 1.9tdi
Hi wondering if anyone can help me with this i've a a4 1.9tdi (110) it starts ok when cold but after running the car and it is warm i need to leave the car to cool down before it will start again it turns over but doesn't seem to catch also the glow plug light flashes when the car is running. I took it to an auto electrician and he told me the MAP sensor was coming up as faulty i replaced this and he cleared the fault and now its a fuel shut of solenoid has anyone any ideas or had this problem thanks in advance.
Old Sep 11, 2006 | 03:24 PM
techbod's Avatar
Default RE: trouble starting 97 1.9tdi
fuel pump injector timing could need resetting or the solenoid is bad, also check the wiring ( other problems could be bad glow plugs ) not expensive to replace and easy job
Old Sep 11, 2006 | 08:02 PM
markf497's Avatar
can i reset the fuel pump timing if so how do i do it or does it need to be done by computer thanks.
Old Sep 17, 2006 | 04:05 PM
markf497's Avatar
i tried the fuel pump solenoid still the same i thought the glow plugs were only for cold start??
Old Sep 17, 2006 | 04:27 PM
techbod's Avatar
glow plugs are to start the car regardless of temp
Old Sep 17, 2006 | 05:20 PM
markf497's Avatar
thanks i'll change them tomorrow
Old Sep 19, 2006 | 03:46 PM
markf497's Avatar
done the glow plugs still the same also noticed that sometimes i can start the car first thing let it run for 30secs or so turn off leave for 10 secs and get same problem leave for a minute or so and it starts no problem. Spoke to local VW garage but they have stopped doing Audi any ideas would be appreciated.
Old Sep 19, 2006 | 06:20 PM
techbod's Avatar
I don't have much data on diesels because I don't work on them much, but I do have ideas of what the problem could be so ill have a go, so the glow plugs have made a small difference now the problem could be a fuel leak letting air into the system so needing to pressure up each time you try to start the engine, have you recently changed the fuel filter?? if yes ensure its sealed properly - next each injector has a pipe going from one injector to the other this is a lubrication for the injectors ( are they wet with diesel ) these pipes are a pig for corroding letting air into the system you can buy a service kit for them which includes a black rubber cap which is at the end of the fuel rail ( another area where the rubber decades ).
basically what I think is happening is air is entering the system when its been switched off which will make it hard to start so any leaks need to be fixed
Old Sep 19, 2006 | 06:50 PM
markf497's Avatar
thanks i'll have a look at them tomorrow.
Old Sep 20, 2006 | 02:01 PM
markf497's Avatar
changed the pipes they needed it but still the same how easy is it to do the fuel pump timing is it a case of slackening the 3 screws and giving it a slight turn or is it better getting it done by a garage??
Thanks.
patchs1970
Oct 26, 2013 03:41 PM
irishgirl
Sep 9, 2013 07:17 AM
talex
Oct 19, 2011 04:26 AM
Dazza
Mar 8, 2008 09:28 AM
raven
Sep 5, 2005 11:13 AM
