TT brake kit installed (312mm)
Old Mar 21, 2007 | 06:45 AM
AteUrV8's Avatar
Default RE: TT brake kit installed (312mm)
hey if you were doing this upgrade isnt it possible to just order drilled rotors for an a8 and just use them as the rotor on your a4..
Old Mar 21, 2007 | 07:11 AM
turboA4's Avatar
lookin good! i like the setup!! those rotors fill up that space like none other! close, perfect fit!
Old Mar 21, 2007 | 07:12 AM
AteUrV8's Avatar
need bigger rims, badly... I have an extra set laying around all scratched up tho lol
Old Mar 21, 2007 | 02:16 PM
wood_e's Avatar
My 17s are at my dads place until I go pick them up.
The point of this upgrade is that you need to use the TT bracket to accomidate the larger rotor. Stock A4 brackets won't fit the A8 rotor.
Old Mar 21, 2007 | 03:29 PM
Lazer Viking's Avatar
yes, you could just get the drilled a8 rotors... but you would still need the tt cariers
to fix your dipping problem put some s4 rear brakes on there
Old Mar 21, 2007 | 04:06 PM
akielb's Avatar
So, This is just for the front wheels and not the rear? or would the rear replacement be similar. The size of the rear rotor is really annoying
Old Mar 21, 2007 | 11:18 PM
thats just for the front.. like i said, you can just put s4 rotors and carriers on the rear
Old Mar 22, 2007 | 09:29 PM
  #18
TeeterTawter's Avatar
what about using the stock front rotor on the rear? would that work or no?
Old Mar 22, 2007 | 10:09 PM
  #19
wood_e's Avatar
Nope - won't work. The bracket won't fit.
Old Mar 23, 2007 | 12:24 PM
  #20
ttay2002's Avatar
Where did you get the carriers?
