turbo
Old Oct 6, 2007 | 02:56 PM
Mya4T's Avatar
Default turbo
some people say that the ko4 doesnt give out enough power. idk how but anyway
what is th next step up from a KO4
and how reliable are they whatever turbo it is
Old Oct 6, 2007 | 04:01 PM
qUaTtRoA4's Avatar
Default RE: turbo
Which Turbo should I get?
This all depends on how much power you want vs. reliability, and how deep your pockets are. The most reliable and easiest one to swap to is a k04-015. You don’t have to swap anything else out. It’s a direct bolt on replacement. But you’re probably going to max out a little under 300hp. The other popular choices are GT28RS, GT2871r, and GT3071r. With a gt28rs you will get more power but you will have to swap a bunch of stuff out as well. It maxes out around 350-375 hp I believe. A gt2871r is going to provide similar results to the gt28rs. The only difference is the gt28rs will spool faster. If you want even more power go with a GT3071R. It maxes out at about mid 400 hp range, I believe. Again you will have to change other stuff as well. If you want detailed info on these three turbos, then check out this link: http://www.atpturbo.com/root/releases/release050304.htm
There are others as well, but these are the popular choices.
Old Oct 6, 2007 | 05:35 PM
Leifer's Avatar
Default RE: turbo
ORIGINAL: Mya4T
Before you get a bigger turbo, I suggest you do general upgrades to your car -- IE a new exhaust system, new intake, fuel injectors, etc etc.
Old Oct 6, 2007 | 09:08 PM
cincyTT's Avatar
I'm make believe
Default RE: turbo
a ko4 will make at most 240-250BHP (not whp) with being pushed hard. If you want more than that, a gt2x elim is about the smallest upgrade that makes good power. I would rather go with a t3 60trim or gt28rs personally
Old Oct 6, 2007 | 11:07 PM
oneg's Avatar
Default RE: turbo
ORIGINAL: cincyTT
+1 for the gt28rs, it seems eveyone with ko4 eventualy realizes they want more, and the gt28rs is the basic anwser. from stock too running a gt28rs you would mostlikely be putting aroun 3 grand into it. theres a kit from atp http://www.atpturbo.com/Merchant2/me...ory_Code=VVWTK. Yet after that you need the fmic and tuning. i hear its worth it though, and its what im saving up for.
03a418tnate
Aug 10, 2010 08:07 PM
mr V8
18
Jun 23, 2006 03:21 AM
DickM
12
Mar 21, 2006 05:15 AM
