turbo issues
Old Sep 15, 2007 | 09:32 PM
quiktsi's Avatar
Default turbo issues
alright so i was having problems with my 01 1.8t as some of you know. it was ticking and no boost. so i take it to my garage and start it up and then it starts blowing mad white smoke. I pretty much think it is a turbo problem. there was oil in the intake so i think the seal blew.
Old Sep 15, 2007 | 09:47 PM
Rdssk8boardr69's Avatar
Default RE: turbo issues
i'm no expert but i believe white smoke means ur turbo is toast
Old Sep 15, 2007 | 10:08 PM
Belligerenceâ„¢'s Avatar
white smoke is burning coolant. oil burns blue or black.
Old Sep 15, 2007 | 10:12 PM
quiktsi's Avatar
well thats why i pulled the turbo out. there was some shaft play. where can i get a turbo not to expensive? maybe ko4
Old Sep 15, 2007 | 10:17 PM
CLX's Avatar
CLX
Zombie Defense Force
Gpopshop!
Old Sep 15, 2007 | 10:37 PM
quiktsi's Avatar
well if seal is blown it would be either. no?
Old Sep 15, 2007 | 11:08 PM
AudiCross's Avatar
if a seal was blown it would explain the issues because these turbos arnt bearing but rther use iol pressure to lubricate and allow the turbine to spin
Old Sep 16, 2007 | 12:07 AM
Lazer Viking's Avatar
the seal being blown would make sense.. k03's are oil/coolant fed.. so the white smoke was burnt coolant
Old Sep 16, 2007 | 02:43 AM
Jovian's Avatar
When I had a ticking it was becuase the wastegate valve on my turbo was shot and would not close all the way. This would also cause your boost issue. I ended up replacing it with a K04
Old Sep 16, 2007 | 03:07 PM
jinnyboo's Avatar
is Gpopshop a legit site?
what's the stock turbo on a 1.8t a4?
