turbo not working? wtf
Old Aug 14, 2007 | 09:54 PM
mnsirx's Avatar
Member
Default turbo not working? wtf
man, my turbo just completly not working. it was working this morning and now it just stoped. this is what i pulled from CEL. i also clearn my maf few times but thats not helping. what i concern the most if the turbo. any idea?
p0102- maf/vaf circuit low input
p1137- manufacturer controlled fuel and air metering
Old Aug 14, 2007 | 10:24 PM
Jeff's Avatar
Zombie Defense Force
Default RE: turbo not working? wtf
sounds like you need a new maf by the codes your throwing. do you have a boost gauge? are you boosting at all? is it making weird noises. do you have any vac leaks? more info on the car, what mods year...
Old Aug 14, 2007 | 11:05 PM
mnsirx's Avatar
Member
at idle guage reads 15-20 vac, when i gun it only goes to 0 and wont go any higher. when i gas it i hear a clinging nose from the turbo area, only the moment i gas it, goes away at high rmp. i dont think i have a vac leak because engine seem to be running fine. can maf do this to the car?
mods:
-GIAC chip
-straight down pip no cat
-DV
-front intercooler
-intake
Old Aug 14, 2007 | 11:10 PM
Jeff's Avatar
ya check the turbo and the wastegate
Old Aug 15, 2007 | 12:44 AM
onepoint8tee's Avatar
Sounds like a bad wastegate to me. You can replace it, but its probably cheaper and wiser to just find a used k03 for $150ish. To check the health of the turbo, take the turbo inlet pipe off and check forplayin the compressor shaft/fins.
Old Aug 15, 2007 | 04:35 AM
mnsirx's Avatar
Member
ok, i just found out that my previous owner had hardwire my maf wires. the maf wires was cut off and was taped and reconnected with a new connector. the new one had was one colored wire which did not match with the original wires. i dont know how he did it or was it install professionally, is there a diagram on this? i have two maf, one orginally in the car and a used one that came with the car. i clean both and tested it, code still there. could it be the connectors? where can i get a new one with instructions to reconnect it?
Turbo_nTonic
Jun 13, 2013 09:06 AM
Stephenwhite990
Dec 23, 2012 12:46 PM
Stephenwhite990
Jul 12, 2011 04:37 AM
AudiForever
Mar 14, 2011 12:58 PM
tongster
Apr 26, 2009 01:56 AM
