turbo problem?
Old Jun 1, 2005 | 02:00 PM
  #21
aRIf's Avatar
Default RE: turbo problem?
u get 400miles a tank ? WOW!!
I have 98 1.8TQ I got about little over 300miles... What do you have myaudia4 ?
Old Jun 1, 2005 | 02:34 PM
  #22
myaudia4's Avatar
I have 98 1.8TQ same thing you have. This is majority highway miles, few local. I just filled up today when my gas sign popped up I had 380 miles already. so what do u think I have turbo problem?
Old Jun 1, 2005 | 02:46 PM
  #23
aRIf's Avatar
I dont know about you but I start to think that I have some problems
Why dont u get a Boost Gauge. Anyway it is something u will buy soon or later. maybe it is time to buy. Instead of try to fix something that u are not sure and spending your money, spend it for somehthing u need. Also you can see your boost level and you can understand if there is a leak...
it is about $85 gauge+pod+parts inc...
http://www.ecstuning.com
Old Jun 1, 2005 | 05:51 PM
  #24
acvega's Avatar
I had this problem in february with that same code. there are two vacuum lines that i replaced and the problem has been gone ever since. it is the two hoses wrapped in cloth. one is a short one that goes from the intake manifold to the fpr, the other i believe goes from the manifild to the Diverter Valve. They were both cracked up like a junkie. replaced them both, unplugged the battery to reset the ecu, after about a day, she was back to normal. FYI - if you turn the radio off and pull the radio fuse before you pull the battery, it shouldn't (key word "shouldn't") ask you for a code when you plug the battery back in and then the fuse.
ryanylva
Jul 22, 2008 09:28 PM
Robertdeeto
Jul 7, 2008 02:00 PM
Johns2000A4Q
Nov 3, 2006 05:01 PM
ooantipostoo
Apr 4, 2006 06:32 AM
bliggity
Aug 4, 2005 05:19 AM
