turbo is shot, replacing with K04
Old Jun 25, 2007 | 11:16 AM
comfort_racing's Avatar
Default RE: turbo is shot, replacing with K04
yeah thats a little scarry to me too. how much and where did you get the cat?
Old Jun 25, 2007 | 12:00 PM
headshok2002's Avatar
I got the cat used, with my exhaust... it's a Brullen.
Milltek costs a fortune... but I think Labree (sp) sells cheaper ones.
Old Jun 25, 2007 | 12:22 PM
cincyTT's Avatar
I'm make believe
so your replacing a perfect working turbo beacuse your pvc system is bad? Makes sense i guess, replacing the wrong thing. A catch can and/or a pvc change with solve the oil issues. If your turbo was bad you wouldnt make boost and you have a massive white cloud out of your exhaust. So if you havent bought the turbo yet...DONT, yours is fine.
Old Jun 25, 2007 | 12:30 PM
ORIGINAL: cincyTT
I was hoping somebody smarter than me would chime in... I knew I was on to something!
Old Jun 25, 2007 | 01:06 PM
could be the pvc. where would the oil be coming in from then? you mean pcv right?
Old Jun 25, 2007 | 01:10 PM
wrigby's Avatar
Check your PCV (NOT PVC!) valve, I guess. If it rattles when you shake it, then it's good. If it doesn't, it's bad.
cincyTT's Avatar
I'm make believe
its oil blow by going back into your intake, through your turbo, and through your ic piping and pooling in your ic.
And its not "could be" it IS just blow by. Do what i said about and you will be fine.
Old Jun 25, 2007 | 01:12 PM
  #18
cincyTT's Avatar
I'm make believe
ORIGINAL: wrigby
christ sakes, i make one damn typo and you act like you knew what his problem was. When its bad, it spews out oil, thats enough of a test.
Old Jun 25, 2007 | 01:13 PM
  #19
uggh, i already bought the turbo....maybe save for a rainy day.
Old Jun 25, 2007 | 01:14 PM
  #20
ok, thanks for the advice. i will check it tonight and hopefully thats it. typos's are graet.
