Turbo sound
Old Dec 10, 2006 | 04:32 AM
  #21
Deleted User's Avatar
Default [Deleted]
[Deleted by Admins]
Old Dec 10, 2006 | 04:42 AM
  #22
turbo kraut's Avatar
Tech Guru
Default RE: Turbo sound
i'll tell kelly to cyber slap you
hahaha
Old Dec 10, 2006 | 04:43 AM
  #23
Default [Deleted]
[Deleted by Admins]
Old Dec 10, 2006 | 05:37 AM
  #24
sean1.8t's Avatar
ORIGINAL: turbo kraut
i have a stratosphere dv, and i still can't hear my dv
and i am not saying you are wrong, cause i am still sort of a newb to this, well trying to learn everything i can, so there is no k03 sport why was did i see that there is more hp for the sport v non sport?
there is a ko3 sport. it has an upgraded shaft('01 only) and the compressor wheel fins are angled slightly more agressive('00-'01).. but it does not attribute to more power.. the more power from the 2001 model comes from a lower compression ratio(.1:1 difference iirc) and a higher factory set psi..
this is why on all chips(other than giac-X) you see the same output. they are all raised to the same psi, usually around 1.1 to 1.2bar, and there for put down very simlar power after being chipped.
BUT BACK ON TOPIC- i can clearly hear my ko3 spool as well as my dv on almost every shift. i attribute this due to a GIAC-X chip, evoms intake, and bailey dv combo
Old Dec 10, 2006 | 05:42 AM
  #25
Jeff's Avatar
Zombie Defense Force
i had a stratmosphere dv and i didnt hear it. it is problaby the design of the valve. becuase even at 40psi i never herd it. but then again my car was so loud it might have been muffled out
Old Dec 10, 2006 | 05:50 AM
  #26
sean1.8t's Avatar
^40psi??? on a ko3 or a BT? i am interested on what you are and or were running
  #27
Jeff's Avatar
i ran 40psi on my t3t4 with stock internals
Old Dec 10, 2006 | 05:54 AM
  #28
sean1.8t's Avatar
haha!! how long did that motor last?
Old Dec 10, 2006 | 05:57 AM
  #29
Jeff's Avatar
its still running with no problems. i sold the car mid summer and i talk to the new owner frequently and its running like a champ. i only ran 40 psi for a few days. it happened becuase the car was tuned in colorado and my dad drove it down to me in texas. i took it out for a few pulls and the boost gauge was spiking at 40psi fast as hell. kept blowing my ic pipes off so i had to turn it down
Old Dec 10, 2006 | 06:02 AM
  #30
BadLuckAudi's Avatar
bah 40psi is nothin
ORIGINAL: Jeff
