TURBO XS HP boost level adjustment
Old Dec 8, 2007 | 01:32 PM
texasboy21's Avatar
Default TURBO XS HP boost level adjustment
I was looking for some user expierence with the TURBO XS HP MBC. I read that the boost level adjustment is made by turning two screws with a hex key or something. How is this to use? There are many MBCs that have a **** on the end which seems to be easier to adjust, but i cant find one that is combo bleed/ball and spring that i am looking for. Is it difficult to set the boost where its not spiky with the tandom adjustment *****?
barrett
Old Dec 9, 2007 | 03:24 PM
texasboy21's Avatar
Default RE: TURBO XS HP boost level adjustment
bump...
Old Dec 9, 2007 | 03:29 PM
chaos92287's Avatar
you cant crank up the boost past what the MAF can correct or you will run lean and fvck your engine up...i coulda sworn i answered this thread already...weird
Old Dec 9, 2007 | 10:29 PM
texasboy21's Avatar
ORIGINAL: chaos92287
ok. how is it adjusting the boost level?? with the two screws it seems like im may be difficult, is it??
barrett
Old Dec 10, 2007 | 01:03 AM
pimptrooper3000's Avatar
its not difficult at all...just watch how high you raise it cause u will blow ur engine...
Old Dec 10, 2007 | 10:16 AM
texasboy21's Avatar
alright thanks im not planning anything stupid
barrett
texasboy21's Avatar
double post......chronic...........smoke one
barrett
Old Dec 10, 2007 | 01:04 PM
cincyTT's Avatar
I'm make believe
Here is mine installed
Best mbc you can by imho. The broze fitting is the ball&spring and the blue end is the bleed valve. You adjust it with a hex/allen key so it cant change while driving or hitting anything. its simple to install and set. Basically for a smooth boost onset, you will set the b&s to about 2-3psi less than target boost and then up the remaining psi with the bleed. With the combination you can get fast spool (b&s) and smooth boost onset (bleed). Let me know if you need any help
Audis4CO
Feb 10, 2015 12:06 AM
m3romeo
Feb 5, 2011 03:38 PM
Babz
May 24, 2008 11:52 AM
Babz
May 21, 2008 04:57 AM
yegappan
Aug 10, 2007 12:45 PM
