TURN SIGNAL RELAY SWITCH
Old Sep 20, 2005 | 12:14 AM
JL AUDI 01's Avatar
Default TURN SIGNAL RELAY SWITCH
ANYONE KNOW THE PROCEDURE TO TAKE THE OLD ONE OUT..
Old Sep 20, 2005 | 02:55 AM
kextyn's Avatar
Default RE: TURN SIGNAL RELAY SWITCH
I just replaced mine the other day. I'm guessing from your nickname that you have an '01? If so all you have to do is pull off the panel around the cup holder and switches. It felt like I was going to break it but its really just held on by some clips that hold on really well apparently. After you get that out it's just a matter of pulling the switch out as it's not really held in by anything but pressure on the sides. To make it easier (and because I screwed up my cupholder and had to fix it) I took out the cupholder and the frame for the 3 buttons on the left. There are 4 bronze colored clips on the top (2 on the cupholder and 2 on the buttons) after you pull those out the units will slide out giving you more room to work with the relay. Just pull it out, unplug it, plug the new one in, and slide it into place.
I know this topic has come up a lot here so you could do some searching for other members who have done it.
Old Sep 20, 2005 | 06:28 PM
JL AUDI 01's Avatar
THANKS FOR THE INFO. SEEMS PRETTY STRAIGHT FORWARD TO GET IT OUT. ONE QUESTION THOUGH, HOW DID YOU TAKE THE COVER OFF, DID YOU REMOVE THE STEREO THEN PRY IT OUT OR SOME OTHER WAY.
Old Sep 20, 2005 | 10:44 PM
kextyn's Avatar
It just pulls straight out. So any way you can get something in the sides to loosen it up will help. Just be careful not to make some deep gouges and stuff in your dash if you slip or something.
wesk11
Jun 6, 2017 10:11 PM
D_Riot
Jul 28, 2010 10:02 AM
benormous
Sep 8, 2008 07:28 PM
Tour de A4
Sep 17, 2007 09:48 PM
tommy
Jun 18, 2007 05:54 PM
