Two Problem with my Audi
Old May 6, 2005 | 06:37 AM
audidriver4life's Avatar
Default Two Problem with my Audi
I currently own a 2003 A4 3.0 CVT. The first issue I have is when I am driving the car. The RPMs are rising then falling every 2 or 3 seconds. So if the RPMs are at 2,000 it jumps to 2,200 then back down. It feels like the car is getting kicked in the rear. When I get above 50 MPH is problem starts to go away. There are no problems while in park.
My second issue is a concern although it hasn't happened for a few months. This has happened only 4 or 5 times. When I start the car and drop it into reverse, the car starts to buck violently. I then placed the car in park, turned it off, restarted it and the issue went away.
Any educated guesses? I'm more concerned about the first issue as it's taking away from my driving pleasure. BTW, I drive my car a lot. It currently has 68,000 miles on it.
Old May 6, 2005 | 08:24 AM
rs's Avatar
rs
Default RE: Two Problem with my Audi
sounds like u mite have a vaccum leak or somethin..
Old May 6, 2005 | 02:27 PM
brrman's Avatar
go to the dealer - I have heard of these problems in CVTs before. I am not sure of its resolution, but I know your issue is not unique.
Old May 6, 2005 | 03:45 PM
SAFE4NOW's Avatar
Brake light switch takes care of 90% of the issues... Drop by the dealership - They should know what to do!
Steve
Old May 6, 2005 | 06:50 PM
Sebass's Avatar
If it feels like your car is getting intermittent boost....like pulling and then stopping and then pulling...it could be your wastegate...it's about a $200 job at the dealer...unless you can do it yourself...
The other problem my car has also...only seems to happen in the cold weather months...if you drop it into drive it won't even move...I have no clue what this is about...but I had some hoses replaced recently and the problem hasn't returned...then again...it's finally warm...
Old May 6, 2005 | 07:00 PM
hb972.8q's Avatar
his car is not a turbo so no wastgate.
cvt is the the funky new auto thing?
Old May 6, 2005 | 07:01 PM
BFlan2001's Avatar
cvt=continuously variable transmission
Old May 7, 2005 | 12:43 AM
VB05's Avatar
thats some interesting stuff
Old May 7, 2005 | 01:34 AM
AUDI05's Avatar
good luck with your problems, man that stinks
marcoetreni
Oct 12, 2009 03:32 PM
cgroff5686
Apr 7, 2009 09:12 PM
Mikesd1980
Jan 11, 2008 11:11 PM
johnstef
Aug 30, 2006 12:42 PM
audidaft
Feb 23, 2006 01:28 AM
